It is currently Sun Nov 29, 2026 3:17 am
Post new topic  Reply to topic  [ 924 posts ]  Go to page Previous 1 … 36 37 38 39 40 … 62 Next
PostPosted: Sat Aug 22, 2020 6:25 pm
Does your carb go into the scoop?
PostPosted: Sat Aug 22, 2020 7:43 pm
The top of the toilet sits right about even with the bottom edge of the scoop opening. You can just see it in the photo.
PostPosted: Sat Aug 22, 2020 7:45 pm
This is the plan. I’ve never done any fiberglass. We will see. Youtube here I come...
PostPosted: Sat Aug 22, 2020 8:18 pm
What can possibly go wrong?
PostPosted: Sat Aug 22, 2020 8:31 pm
I’ll jack it all up and not have a usable hood... :?
PostPosted: Sun Aug 23, 2020 10:54 am
Run it as is and change the hood over the winter. Fiberglass is not that hard to work with, just messy.
PostPosted: Sun Aug 23, 2020 11:57 am
Rick, where do you get your supplies?
Steve Dulcich has a Roadkill Extra video on YouTube. He’s cool. 8)
PostPosted: Sun Aug 23, 2020 12:06 pm
I think I bought the fiberglass mat at Walmart in a kit but that was several years ago. It was like a 3' X 3' piece of the material. The resin / hardener I just picked up at the hardware store locally when I glassed in the rear hood hinges on my fiberglass hood.
PostPosted: Wed Sep 02, 2020 10:11 am
I got the Challenger mostly ready for some testing at Ohio Valley tonight.
I've run it through the gears on jack stands a couple times, installed new 5 point harness, checked all the fluids, bolts, etc.
I need to wire a taillight and secure the decklid better, but I should be able to knock that out this afternoon. Track opens at 6...
PostPosted: Wed Sep 02, 2020 12:25 pm
good luck, be safe.
PostPosted: Wed Sep 02, 2020 1:39 pm
Woo Hooo!! Report at 11!! Or from the track.
PostPosted: Thu Sep 03, 2020 3:03 am
How did it go? :?: :?:
PostPosted: Thu Sep 03, 2020 4:57 am
It was raining, so I just went to the garage and fiddled with wiring the taillight and mounting the trunk lid.
Things in the garage are still a cluttered mess. I couldn’t find any of my wiring kits (I probably have 3). I was able to find an old, rusty wire stripper and some used wires out of other cars that I could use for the taillight.
I’m not happy with my hokey fix on the trunk lid. I need to get some 1/4 turn fasteners and do it right.
I’m moving Chase to Lexington tomorrow, but if I make it back in time and the weather is good I’ll try again. I’ve got 3-4 more opportunities before Clay City, so hopefully I’ll get there.
PostPosted: Sat Sep 05, 2020 9:30 pm
Just got home from the garage. Weather forecast is good for tomorrow and the track opens at 10:30....
I guess I’m finally gonna try this.
I had to jury rig some bushings for the rear shocks this evening. They had completely deteriorated to where there was nothing left at all. Luckily I’m a hoarder and had recently swapped some leaf springs around and I kept the old bushings. A little cuttin’, some WD40 and the shop press had ‘em replaced in no time. :lol:
PostPosted: Sun Sep 06, 2020 5:14 am
Best of luck, Rob. Hope you have a great first outing.
