It is currently Sat Oct 10, 2026 9:30 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Aug 20, 2020 7:55 pm
How hot can you get the gear before you have to worry about any heat treating it may have?
I'm just wondering if the technique I used with my lawn mower flywheel would work.
I cranked up the gear puller, then took my plumbers torch to the flywheel. After about a minute the flywheel popped loose.
PostPosted: Fri Aug 21, 2020 10:16 am
Kinda complicated because this is dependent on the amount of carbon in the iron / steel.
In general, you will not impact hardness if you stay under 1000 degrees F.
See this paper for more detail:
http://www.heat-treat-doctor.com/docume ... tIrons.pdf
PostPosted: Thu Sep 03, 2020 8:36 pm
I agree there is no one magic threshold temperature, but physical properties start to change I believe as the material approaches 700F.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 31 guests
