It is currently Tue Nov 17, 2026 10:52 am
 Post subject: Valve springs
PostPosted: Tue Nov 03, 2020 5:17 pm
So I’ve been reading enough to be curious or dangerous lol. Looking at valve springs
beehive style has advantages and disadvantages I have 3/8 valve stem diameter beehive style real advantage is at max rpm I believe 90% of the time engine won’t be there .
Cam lift is .504 with a 1.6 rocker ratio solid lifter
What style or brand springs do you recommend thanks
I’m looking at max rpm of 5500
1963 Plymouth Valiant Wagon
 Post subject: Re: Valve springs
PostPosted: Tue Nov 03, 2020 7:17 pm
what is really important is to get the spring height and pressure right.
But when deciding between conventional and beehive springs,, beehive sprigs offer the undisputable advantage of less weight at the top of the spring itself and at the retainer.
If you are spending extra $ to reduce valve train weight to use light weight: lifters, valves, push rods, it makes sense to carry that plan over to the valve springs.
If you are not doing anything extra to cut weight like going to smaller valve stems, or anything else,, I would stay with conventional springs.
PostPosted: Tue Nov 03, 2020 8:05 pm
I have the engine builder valves 3/8 stem
PostPosted: Tue Nov 03, 2020 8:46 pm
Nothing wrong with conventional valve springs, they have been used in many fine engines for many years.
Your cam shaft supplier should have info on spring pressures, I am thinking the Engine Builder valves install at the stock slant spring height. You can shim under the spring to go up slightly on pressure or cut the springs seat to reduce it.
PostPosted: Wed Nov 04, 2020 10:31 pm
At a touch over .500" lift and 5500 rpm, you won't need a whole lot of spring anyway.
PostPosted: Thu Nov 05, 2020 2:20 am
I agree and the cam says only 130 to 140 lbs seat psi
Just looking for extra hp a free pony lol I need to buy springs anyway lol
PostPosted: Thu Nov 05, 2020 8:13 am
Can you even get beehive retainers for 3/8" stems? Asking for me, I don't really know.
When I was running that low of lift Mike stayed with stock 340 springs.
PostPosted: Thu Mar 04, 2021 10:32 am
found this post at FABO, has photos and part numbers for beehive valve springs that fit 3/8 valve stems
https://www.forabodiesonly.com/mopar/th ... 1973373827
PostPosted: Thu Mar 04, 2021 2:03 pm
When I ran my .506/.513 lift cam I ran the Enginebuilder springs that were basically 340 springs I think. They worked fine and I was turning over 6000 rpm.
PostPosted: Thu Mar 04, 2021 5:37 pm
They would hold up on a 340 to 6500. Weight has to be less with a Slant valve, but I guess we make up for it in pushrod weight.
Users browsing this forum: Amazon [Bot] and 11 guests
