It is currently Sat May 23, 2026 5:57 pm
PostPosted: Wed Jan 20, 2021 12:20 am
Car Model: 66 Valiant 200
I bought an Offy intake with dual Webers about a year ago. I’d like to finally install the thing, but I’m not sure how to go about it because I have the rotating rod linkage for throttle and kickdown. Has anyone installed the ProLine setup with the rod linkage or will I have to change to cables?
Washington, Jefferson, Twain, Luther, King, Peewee Herman.
PostPosted: Wed Jan 20, 2021 8:57 am
I would say to switch to a cable throttle and eliminate the rod.
If you wish to keep the stock looking gas pedal It could be used with a cable setup from a 1972-1978ish d series truck.
PostPosted: Wed Jan 20, 2021 3:54 pm
You're really getting into the area of hot rodding that involves making your own stuff, as opposed to kits and pre-made parts. I agree, switch to a cable and that will at least make and easier starting point.
PostPosted: Wed Jan 20, 2021 4:19 pm
Picked up the early A v8 pedal assembly at the wrecking yard today. 30 bucks and life got a whole lot easier
PostPosted: Wed Jan 20, 2021 4:51 pm
The fact that you have access to one of those in a wrecking yard is stupendous!
PostPosted: Wed Jan 20, 2021 5:19 pm
I lived in Mountain View, CA for 3 years in the mid 1990s. I spent plenty of time in the wrecking yards. I had three A bodies to maintain and improve. :D
