It is currently Tue Sep 29, 2026 8:40 pm
Post new topic  Reply to topic  [ 146 posts ]  Go to page Previous 1 … 6 7 8 9 10
PostPosted: Thu Mar 19, 2020 3:44 am
I am running 14 psi (max) on my 68 Dart and it works very well and is reliable. Usually I run 11 psi on the street, which still plenty of power.
Enjoy the drive,
PostPosted: Fri Mar 20, 2020 1:16 pm
Car Model: Valiant -66 turbo
Slant 225 coming from a Belvedere 63. A guy did an engine swap to v8.
Now this is resting in my garage . good spare engine..
I am doing a new trigger bracket, the old one was very close to the electric fan..
Thomas
PostPosted: Sun Mar 22, 2020 1:23 pm
Trigger bracket soon finish.
Just need to adjust the lash between sensor / trigger.
The old bracket was adjustable sideways, in case you pull the harmonic balancer and cant line it up when put back
Al the best Thomas
PostPosted: Sun Mar 22, 2020 3:32 pm
Will you be machining the dampener so that it doubles as the trigger wheel?
PostPosted: Sun Mar 22, 2020 5:00 pm
Hello Greg,
Sorry can you explain a bit more..
"machining the damper so that ..etc :?:
PostPosted: Sun Mar 22, 2020 5:09 pm
Nevermind.
I see in the second picture that you have a trigger wheel bolted in front of the damper.
PostPosted: Sat Feb 06, 2021 11:47 am
Hello,
Some new stuff..
A 3 way fuel tap, so you can choose to use ordinary or a small fuel tank in the trunk.
And its regulated from the trunk
Can bee good to run an e85 car on ordinary pump gas now and then to clean the injectors ,runners and other Components
Just one more thing to do , hang Up the fuel hose properly some places
Its -5 Celsius , 23 farensomething.. and i am working outside..
PostPosted: Sat Feb 06, 2021 12:05 pm
Trunk
[url][url=https://www.bildtagg.se/bild/xfjlppfg4x63hxged1snrfg]Image[/url][/url]
PostPosted: Sat Feb 06, 2021 4:21 pm
Nice work,
Soon the frost and snow will be gone and it will be up to a Balmy 15° outside.
PostPosted: Sun Feb 07, 2021 7:51 am
Thanks Greg,
Yes the spring can be around the corner..
Fuel tap access from the trunk
[Image]
PostPosted: Tue Feb 16, 2021 5:24 am
I found an quite nice gearing calculator.
https://www.blocklayer.com/rpm-gear.aspx
Set your gear ratio,tire size etc.
And this turns up
A lot of info to get, how different gearing and tire size affecting rpm and speed
[url=https://www.bildtagg.se/bild/s8v44 ... 15om[/img][/url]
Also this page was very interesting
Learning curves a race friendly dyno graph
https://dsportmag.com/the-tech/learning ... yno-graph/
