It is currently Sat Nov 14, 2026 3:05 am
PostPosted: Tue May 18, 2021 11:18 am
Car Model: 1966 Dodge Dart
The crank trigger is a prototype that was intended for a small block Chevy. I'm going to use a threaded Hall effect sensor here and a bit of square tubing welded to the timing cover. Some work in progress pictures:
My welding skills aren't the greatest, but at least I don't have any more holes in the timing cover than I started with.
Matt Cramer
PostPosted: Tue May 18, 2021 12:38 pm
Hi Matt,
Looks very similar to what I did on mine. See pics at: https://flickr.com/photos/16910097@N06/ ... 2740650932
I used your cam sensor (fuel pump plate) idea and it is perfect! Thanks again.
PostPosted: Wed May 19, 2021 10:31 am
Looks like you were a bit more confident in your welding skills getting the gap right than I am! I went with a threaded Hall effect sensor. Everything ready now except paint and finishing the wiring.
Matt Cramer
PostPosted: Wed May 19, 2021 7:18 pm
Is that a 36-1 wheel?
PostPosted: Thu May 20, 2021 6:52 am
Correct.
Matt Cramer
PostPosted: Fri May 21, 2021 11:44 am
Yes but it's a prototype SB chevy one that bolts nicely to the Romac for a slant 6 - would like matt/ Diyautotune to make some more of them... wink wink, nudge, nudge.
