It is currently Thu Apr 30, 2026 4:54 pm
 Post subject: shift lever adjustment?
PostPosted: Sat Jul 17, 2004 1:12 pm
Hello all
Other than the obvious 1/2 " bolt and sliding bar in the automatic shift lever linkage, is there a way to adjust the slack out of the shift actuating lever on the trans? Mine seems to be quite sloppy after I have adjusted the linkage six ways from sunday and have narrowed it down to the shift lever.
My car is a two door sedan 68 Signet with a 225 and a column shift A904.
Any help would be great,
'68signet
"Living analog in the digital age."
PostPosted: Tue Jul 20, 2004 11:06 pm
Did you check the kickdown lever's "slop" with the engine running?
The lever will be harder to push when the trans has pressure.
There is a travel limit adjustment for the kickdown lever but it is on the valvebody, you will have to drop the trans pan to make that adjustment.
PostPosted: Wed Jul 21, 2004 6:45 am
Thanks Doc, I'm going to install a B&M shif kit soon so I will be able to check out the lever adjustment on the valve body. I will first check the lever while the engine is running (properly secured to jackstands!!) to see if I can figure it out.
'68signet
