It is currently Wed Jul 15, 2026 12:44 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Mon Aug 08, 2022 5:31 am
Yes, you can put it on the top of the rocker too. Any backlash or flex in the rocker assy or slip between pushrod and rocker might reduce accuracy, but i have never tried it to know. If it were me, I'd still use a stock solid lifter pushrod... I imagine the dial indicator ball will not sit reliably on the pushrod oil hole. Yes, pull rocker shaft.
PostPosted: Mon Aug 08, 2022 6:51 am
Car Model: 64 Valiant
Yes, you could set the indicator on the pushrod side of the rocker if you had a solid lifter installed, but with a hydraulic lifter, you will be fighting valve spring pressure bleeding the lifter down as you rotate the engine, causing inconsistent readings on your indicator. So removing the shaft may be your best option.
PostPosted: Mon Aug 08, 2022 7:22 am
Ah, yes. Lifter bleed down under valve spring pressure is the other reason not to leave the rockers connected. I have never run a hydraulic engine...
Users browsing this forum: Amazon [Bot] and 6 guests
