It is currently Sat Nov 21, 2026 5:51 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
 Post subject: Shorty Kit for a 904
PostPosted: Wed Nov 16, 2022 4:02 pm
Car Model: Front Engine Dragster
Looking for a shorty tail shaft kit for the 904 ?
Need for a F.E.D. project.
Thanks !
Jeff
 Post subject: Re: Shorty Kit for a 904
PostPosted: Wed Nov 16, 2022 5:01 pm
AFAIK, no. There were some 727 kits floating around.
A&A in Indianapolis might have built one as a custom deal.
PostPosted: Wed Nov 16, 2022 6:46 pm
I found one for sale back in 2018 on another sight, but no info on who made it.
Said it had GM TH350 splines.
PostPosted: Wed Nov 16, 2022 8:38 pm
Pretty sure Charles Meyer had one built for his back motor dragster. I thought he had A&A do it.
You're in custom territory for sure.
PostPosted: Thu Nov 17, 2022 6:32 am
I believe Fopar used a Jeep transmission hybrid to shorten the length in his RED, but it may not be as short as you want.
PostPosted: Thu Nov 17, 2022 10:13 am
That makes sense as a 904 equipped jeep would have that 904 feeding a transfer case.
Just need the great FoParian to chime in and confirm.
PostPosted: Thu Nov 17, 2022 12:05 pm
Just for reference, a F**D C-4 shorty is approx. 20" long and it fits.
PostPosted: Thu Nov 17, 2022 12:38 pm
I think CJ used a shorty Powerglide in his FED.
PostPosted: Fri Nov 18, 2022 9:06 am
I found this post from 11/17/2011 by Ceeg & Fopar
That should be out of a late 80's 4x4. Not exactly sure. Fopar thinks he saw one behind a four banger jeep.
We turned that housing down quite a bit on my lathe, so it's not going to look exactly like that. I still haven't pulled the table and reinstalled the chuck. Need to do that... :lol:
Make sure to grab the transfer case and pull the front input gear. You will need that to make up a coupler. Mark Williams sells parts to make the coupler up.
http://i77.photobucket.com/albums/j59/r ... 000424.jpg
PostPosted: Sat Nov 19, 2022 6:26 pm
Yessir. I've only got two gears though. Fopar would be your source for Brilliance and proper bits for the 904. Been a while since we built that particular solution!
PostPosted: Mon Dec 19, 2022 3:59 am
A little late but that shorty kit is the one I made for the green grenade. I sold it with a bunch of small block stuff to a guy that worked for Crower. The stock 904 shaft was cut and resplined by Mark Williams and they were reasonable on the labor.
The 904 was worthless in the dragster. You could not even think about leaving it in first gear as it would wheelie big time. Powerglide is the way to go.
4:10 gear was too much gear with a 29.5 tire in our application.
Mark
PostPosted: Mon Dec 19, 2022 6:37 am
Mark
Cool Stuff,
Thanks for your insights Mark!
PostPosted: Mon Dec 19, 2022 9:05 am
T
That's some good information Mark! :D
Wish I could get a little "wheelie" out of my Valiant!!! :D :D
PostPosted: Tue Dec 20, 2022 5:34 pm
Off topic, Rick, replace your front rubber a arm bump stops with some big bolts.
Adjust for zero travel, and voila, little wheelie!
PostPosted: Wed Dec 21, 2022 6:50 am
:D :D
