It is currently Fri Nov 13, 2026 9:19 pm
PostPosted: Mon Nov 21, 2022 1:03 pm
Dear Slant 6 sages,
I am contemplating running Microsquirt on a new/upgraded EFI system on one of my cars. This little bugger appears to have about everything I would need for a "non-all-out" EFI system. I would be upgrading from 2003-vintage MS-I ECU and will run port EFI and likely coil pack (wasted spark) ignition. I have MS3X (more functionality) running on the Project V Valiant, but feel that the Microsquirt would likely do everything I want at a fraction of the price ($400 vs. $800-1600 for MS3 or MS Pro). It seems you also need an external MAP sensor for Microsquirt, which is about $100.
I am wondering if any of you are running Microsquirt. What are your experiences and/or how do you feel about it?
Anyone contemplating using Microsquirt and have thoughts?
Thanks!
PostPosted: Mon Nov 21, 2022 5:17 pm
I have a Microsquirt, but I am not running it yet. Mine has the modification to run LS coils in wasted spark mode. I feel it needs a couple of extra outputs to control stuff. I am surprised that DiyAutoTune hasn't come out with an expansion box to connect to the CAN bus. (Matt, hint... hint... hint...)
PostPosted: Tue Nov 22, 2022 6:44 am
Thanks, Kesteb. One of the extra outputs can be used to do 3 ign outputs for wasted spark. Seems sensible to me. Only thing you miss is sequential (separate inj outputs), but that does not seem like a big loss to me.
PostPosted: Tue Nov 22, 2022 3:37 pm
It also won't run the IAC sensor for GM based throttle bodies. But there is a box that you can wire in to do so. Except you loose those extra outputs to run the LS coils.
PostPosted: Wed Nov 23, 2022 6:46 am
I have never hooked up IAC on any of my stuff, so that would not be a big loss.
PostPosted: Sat Dec 03, 2022 5:41 am
Car Model: 1966 Dodge Dart
The MicroSquirt has been my go-to recommendation for someone who wants a basic MegaSquirt for a while. At this point, the only reasons I'd recommend a regular MS2 are (1) really wanting to build a kit, (2) needing stepper IAC or peak and hold injector control, or (3) wanting an easy upgrade path to MS3 later.
Matt Cramer
PostPosted: Sat Dec 03, 2022 8:37 am
Great, thanks Matt! That is very helpful from someone as knowledgeable and experienced as you. At some point I will probably upgrade my MS1 on the turbo (torqstorm pending) 68 Dart to Microsquirt.
Best wishes,
