It is currently Sat Oct 24, 2026 10:41 am
PostPosted: Fri Jan 27, 2023 5:19 pm
Any secrets to getting one out?
Tried heat, vicegrips (worthless), side cutters, little chisels, etc.
No joy yet.
I need to polish a crank nose.
PostPosted: Fri Jan 27, 2023 6:01 pm
Online
Weld some scrap metal to it.
Long metal.. Grind a slit in it. Then weld the metal with the slit onto the key. Hammer it out.
PostPosted: Sat Jan 28, 2023 3:05 pm
Tap on one end of the key with a hammer. This should raise the other end. Then use a center punch on the raised end to remove the key.
PostPosted: Sun Jan 29, 2023 2:33 pm
I've done what Kesteb said. If stuck, heat with propane torch, hit with PB Blaster or similar, or a wax candle, and try again. Normally I never touch mine, only if damaged.
PostPosted: Mon Jan 30, 2023 5:14 am
Car Model: '23 T-bucket
Really! Maybe I'm overly cautious, but I'd be concerned about removing too much metal, and having a loose fit for the balancer.
Why are you polishng it? Trying to get rid of a seal groove?
I wonder if some previous owner glued it in place?
Roger
PostPosted: Mon Jan 30, 2023 6:59 am
Rusty on the end.
PostPosted: Mon Jan 30, 2023 7:56 am
Molasses solution soak follwed by wire wheel?
PostPosted: Sun Feb 05, 2023 5:59 am
Did you get out? :D
PostPosted: Sun Feb 05, 2023 7:03 am
Nope
I had to move over to another crank
I got it to move up a bit on one end but could not get under it
PostPosted: Sun Feb 05, 2023 8:08 am
Online
I had a similar problem.
That is why I used the method I mentioned above.
This of course was an in vehicle/ in block solution too.
PostPosted: Sun Feb 05, 2023 6:58 pm
I havent given up, just doing some other stuff.
Users browsing this forum: DuckDuckGo [Bot] and 9 guests
