It is currently Fri Nov 13, 2026 6:32 pm
PostPosted: Sun Jan 29, 2023 1:38 pm
Car Model: 1966 Dodge Dart 170 slant 6 4 speed od
has anyone used the hydraulic clutch kit from brewers transmission? I am very interested and would like to know if anyone has installed it
PostPosted: Sun Jan 29, 2023 1:59 pm
I have a similar system in my race car.
The system works fine, but....
You have to get the linkage from the pedal to the master cylinder correct.
You have to add another master cylinder to the firewall.
Mine uses a hydraulic throw-out bearing.
PostPosted: Tue Jan 31, 2023 3:46 pm
Thanks for the input I know I have to do a few modifications
PostPosted: Wed Feb 01, 2023 9:30 am
This is what i did on my car..
it was Not a kit, Sourced the parts myself.
https://www.slantsix.org/forum/viewtopi ... &start=434
PostPosted: Mon Feb 20, 2023 6:30 am
Unless I were really worried about originality, I'd never use a mechanical clutch linkage...the hydraulics work too well. They also free up space underhood. I used a McLeod in mine, you just have to buy the right part number for your trans.
PostPosted: Mon Feb 20, 2023 9:11 am
A Clutch Flight?? :D :D
PostPosted: Sat Feb 25, 2023 7:02 pm
Yep...the only 904 Clutchflite around...and the only one behind a Slant Six lol
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
