It is currently Sat Oct 24, 2026 3:51 am
 Post subject: Engine crank
PostPosted: Sun May 07, 2023 4:17 pm
Car Model: 1982 dodge Van
I have a 1983 Dodge Van Slant 6 needing a crank. Any leads out there?
Thanks
 Post subject: Re: Engine crank
PostPosted: Sun May 07, 2023 5:28 pm
What part of the country? That may help figure out if one of us can help ya. There was a guy in Indiana who had an ad here that has a couple of engines he "has to" get rid of....
Can your crank be machines for undersized bearings?
Another idea is the parts stores used to sell a "crank kit" which was a remachined crank and included bearings to match the degree of machine work.
PostPosted: Wed May 24, 2023 2:17 pm
Thanks
I'm pretty sure all my cranks are forged, but I've read you can fit those in a later block. Where are you located? I might have something for ya.
1963 D100: 3-on-the-tree, 3.50 rear, mostly original, stainless bore clutch slave & brake master, rebuilt speedo, original rebuilt carb.
1961 D200: crew cab short bed, sold.
1965 D500 Crew Cab, planning a 6V92 swap and 6x6 conversion.
PostPosted: Wed May 24, 2023 2:22 pm
Nope. No forged crank in a block meant for a cast one.
PostPosted: Wed May 24, 2023 2:27 pm
Yeah, I'm learning that. haha! You could try car-part.com and see if you can get lucky and find a wrecking yard that has one. It's worth looking, you never know.
PostPosted: Thu May 25, 2023 8:56 am
Autozone used to offer a crank and bearing kit, as did most parts houses.
