It is currently Thu Jun 11, 2026 12:29 pm
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 140 41 42 43 4481 Next
PostPosted: Tue Jul 04, 2023 8:09 am
Sells Webers to Rick, bolts on Clifford with 600 Holley DP, goes fast. :mrgreen:
Please don't hit me. :lol:
I won't hit you!
You make me laugh, well sometimes.
4 barrel back on is in the plans.
Transmission first.
PostPosted: Tue Jul 04, 2023 8:30 am
I'm at 11.5 to one and run 112 and 93 non-ethanol mixed 50/50- Which is 102. With my cam I may not even need that but I don't know how to detect pinging with open headers. :D :D
PostPosted: Tue Jul 04, 2023 8:33 am
That is my problem!
Not enough compression!
Dang it!
PostPosted: Tue Jul 04, 2023 9:27 am
I went high 12's/103 @2775# with a 10-1 motor and 4.10 gears. Compression is not stopping you. :mrgreen:
I picked up .7 and 7 mph with just timing and jet changes, stuff that shouldn't have changed much, did.
PostPosted: Tue Jul 04, 2023 9:31 am
That is my problem!
Not enough timing or jet changing!
Dang it!
PostPosted: Tue Jul 04, 2023 12:18 pm
I think the compression ( or lack of) is utilized by the installed cam timing as well that timing interacting with the cam specifications.
PostPosted: Tue Jul 04, 2023 1:06 pm
What did he say?????
PostPosted: Tue Jul 04, 2023 1:47 pm
Smart guy stuff. That's why he's faster than both of us. :mrgreen:
PostPosted: Tue Jul 04, 2023 2:27 pm
Oh nohedidnt.... :D
PostPosted: Tue Jul 04, 2023 2:38 pm
That leaves me out too! And he goes faster than me three! :D :D
No one ever mistook me for doing smart guy stuff, ever! :D
PostPosted: Tue Jul 04, 2023 3:59 pm
That is my problem!
I aren't smart enough!
Dang it!
PostPosted: Wed Jul 05, 2023 12:29 pm
Thanks Dennis, again.
Got to keep this bus rolling.
PostPosted: Fri Jul 07, 2023 1:05 pm
Got everything to put the new trans together....except the case.
Case was shipped but returned with incorrect address.
Can't make this up.
PostPosted: Sun Jul 09, 2023 11:27 am
I don't learn something everyday, but caught this one today.
Working with a friend in Australia on Weber carb tuning.
If know Weber's, each carb has a throttle return spring inside the carb.
Add the mandated dual return springs by NHRA and you have 5 springs to work against.
I came out to check model numbers and noticed the main linkage lever was shifted.
The foot pedal hooks to this lever.
So as it slips you go from full throttle to 2/3 throttle.
Well that is a real problem, this has caught me more than once.
You can see in the picture the gap has closed up.
It doesn't really matter how tight the little bolt is, if that gap is gone, it isn't going to lock on a smooth shaft.
Going to increase the "gappage" and mark on the rod the correct position.
Looks like this will be an every round check point.
Also got the main shaft and extension housing together on the A-833.
Liberty Gears modified 3.09 gear set.
If you look close you can see the "Dogs" on the gears and the modified "clutch sleeves" that engage the dogs.
Now just cleaning parts to build a complete box.
PostPosted: Sun Jul 09, 2023 2:07 pm
Hopefully that will fix you up! Plus it is not that hard of a fix. :D
