It is currently Sat Oct 24, 2026 3:42 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: Re: Erratic timing
PostPosted: Tue Nov 14, 2023 2:43 pm
It's entirely possible that someone somewhere along the way swapped carburetors out on your engine. But the stock 1bbl for the year of the truck would have been a holley. and again for the year of the truck it was possible for it to have come with a Carter carb, but for that year the only Carter that Dodge used was a 2 bbl.
PostPosted: Tue Nov 14, 2023 5:33 pm
Car Model: '23 T-bucket
I cannot seem to upload pictures of the carburetor it has one Venturi and two bolts and it says Carter. If I can figure out how to upload pictures to the site I will send pictures of the carburetor
OK, then. You've visually confirmed that it is a single barrel, so "we" all KNOW that the truck has been modified from original.
I'll leave the tech response to those that know more about the lean burn system.
Roger
PostPosted: Wed Nov 15, 2023 3:04 am
Car Model: 1983 d150
Rodger thank you so much for your help. I have had nothing but problems out of this carburetor. I am going to do the lean burn conversion what carburetor do you suggest?
PostPosted: Wed Nov 15, 2023 3:07 am
It has a one barrel Aluminum Intake
PostPosted: Wed Nov 15, 2023 10:23 am
That model carb was always regarded as being better than the Holley that would have been stock. Maybe find another?
Users browsing this forum: Google [Bot] and 17 guests
