It is currently Mon May 12, 2025 3:34 pm
Post new topic  Reply to topic  [ 1135 posts ]  Go to page Previous 153 54 55 56 5776 Next
PostPosted: Fri Feb 09, 2024 7:13 am
Does anyone have the specs of the STX-21 cam?
PostPosted: Fri Feb 09, 2024 8:54 am
PostPosted: Fri Feb 09, 2024 11:24 am
272° @ 0.050" is some pretty serious stuff with over 1/2" lift. Effectively Larger than my Ruster cam.
Cool Stuff.
I am guessing it's a flat tappett, not a roller Lobe/ Lifter, correct?
PostPosted: Fri Feb 09, 2024 1:28 pm
Go big or go home! Go Stan Go!!!! :D :D
PostPosted: Fri Feb 09, 2024 1:35 pm
I've got a couple Mike cams that are over .600" net.
PostPosted: Fri Feb 09, 2024 4:28 pm
I am not certain that the lift is the biggest player.
It of course helps but I think the lobe profile/rate and lobe timing to the position of the piston in the cylinder have a large impact on things too.
PostPosted: Fri Feb 09, 2024 4:42 pm
Mine in the car now is 270 degree @ .050 and .570 lift. Most lift above .500 is just a "valve spring test" :D :D
PostPosted: Fri Feb 09, 2024 9:39 pm
Anything under .550" is a lawn mower cam
:mrgreen:
PostPosted: Sat Feb 10, 2024 6:17 am
:mrgreen:
THERE IS MY ZILLA!!!!!!!!!
PostPosted: Sat Feb 10, 2024 11:54 am
I thought you were not going to build another street engine.
PostPosted: Sat Feb 10, 2024 12:11 pm
OUCH! :oops:
PostPosted: Sat Feb 10, 2024 12:23 pm
Mark That is too funny!! :D :D But I do have to say that I am driving my car on the road with about that same cam!! :D
PostPosted: Sat Feb 10, 2024 5:15 pm
Zilla Junior!
And the hits keep coming!
Gary said this was a good one.
PostPosted: Tue Feb 13, 2024 6:19 pm
What a compliment as long as Slantzilla is not offended. I will wear this name as a badge of honor!
Jr.
PostPosted: Wed Feb 14, 2024 1:53 am
:D :D
