It is currently Wed May 27, 2026 6:31 am
Post new topic  Reply to topic  [ 1346 posts ]  Go to page Previous 180 81 82 83 8490 Next
PostPosted: Mon May 08, 2023 9:18 am
Super nice runs Greg! Great consistency! :D :D And Fast!
PostPosted: Mon May 08, 2023 9:25 am
Could be faster...
Could be more consistent...
there is still work to do. :D
PostPosted: Mon May 08, 2023 9:48 am
Could be faster...
Always more work to do........ :oops:
PostPosted: Mon May 08, 2023 9:54 am
Most of the work is on the driver's end of things. :D
 Post subject: 5/9/23
PostPosted: Tue May 09, 2023 6:38 pm
At the mason dixon race sunday morning I started up the car and realized that there was no alternator charging.
I swapped on the new spare alternator that I had with me.
Still no charging.
I suffered through all of sunday's rounds with running on less than 12VDC whilst the engine was running.
I got to thinking maybe this new little denso unit needs that sense wire plugged in.
I tried it tonight and yep.. it sure did need that sense wire.
I have a good 13.8VDC or more volts at the battery with the engine running now.
I Also had been running fixed timing for a number or years now with megasquirt.. i have tried 26°,28°, 30°, 32°, 34°, with no apparent performance advantage.
I loaded a timing map into the computer .. will hafta see if that helps anything out sometime.
 Post subject: 4/21/24
PostPosted: Sun Apr 21, 2024 6:01 pm
No Local TNT's here yet. Still too wet from the last 2 weeks of rain, and its getting cold again, back down into the 30's over night due to the clear skies.
Maybe a dry weekend will happen soon.
I removed the car from Storage and Bought some new Rear slicks.
I have run 28 x10 -15's since I have put the car together.
I bought some 29 x11 -15's. I will have to see if they fit. Hopefully I can get to that this week.
PostPosted: Sun Apr 21, 2024 6:25 pm
Cool stuff Greg! Hope you get some good weather soon.
PostPosted: Mon Apr 22, 2024 6:42 am
Thanks, Dennis, we shall see if this all works out!
 Post subject: 4/23/24
PostPosted: Tue Apr 23, 2024 6:47 am
I test-fit the larger slicks last nite. Also did some cautionary trimming and mounted the other tire, balanced both, and set the car down to confirm fitment. It felt like old times cutting some rust off of this old body. I maybe lost 2 oz. of the car if that... it was not much, but reminded me of circa 2013 when I was slicing and dicing this thing all of the time! I really need to get back to some of that.
I aired up and ballooned the diameter of the tires a bit in anticipation of airing them back down to maybe 8 PSI. The ballooning should confirm that they clear everything in the wheel well.
I also removed the storage tires/wheels from the front, put the front runners on, and installed the side skirts. I plan on going to the first Local TNT on Friday nite. No rain is planned for a few days here so that should be nice and welcomed by all of the local racers and low-lying communities, as they have been getting high water lately.
We'll see if the larger tire diameter and additional ~4 of circumference will help ET or MPH??!? we shall find out.
 Post subject: 4-28-24
PostPosted: Sun Apr 28, 2024 8:18 pm
I went to the local Test-n-Tune on Friday at the local Acceleration Testing Facility.
All went well - Nothing surprising.
It seems the car might be a bit faster on the 60' times by a few hundredths, and also the wider and taller slicks seems to have slowed down my MPH by ~4MPH from 111-112 to 108, not super happy about that.
All 3 runs were in a pretty good headwind, so that might have something to do with it.
I put down 2 1/4 Mile passes that were exactly the same so if anything, the taller / wider tires make things way more consistent somehow, or maybe that is just because they were brand new slicks?!??!!
Here is some documentation... :-)
Ready to meet up and race with some more slanted folks at Mason-Dixon in a few weeks! Yee Haw!
PostPosted: Sun Apr 28, 2024 10:24 pm
With a loss of 4 mph I would expect wind myself.
PostPosted: Mon Apr 29, 2024 10:20 am
Sounds great, Greg, except for the missing 4 MPH. See you in the other lane at Mason-Dixon!
PostPosted: Fri May 17, 2024 3:31 pm
Found some more Documentation.
PostPosted: Fri May 17, 2024 8:57 pm
Awesomeness Greg! :mrgreen:
PostPosted: Sat May 18, 2024 7:33 am
We'll see what happens this weekend.
The mason dixon street race event for today that Lou, Rick and I quasi planned to attend is rained out.
