It is currently Sat Jun 13, 2026 2:34 pm
PostPosted: Fri Oct 25, 2024 2:28 pm
From what I can gather i have a 4 speed t-170 behind my slant six 83. They did a really bad job of doing it and I'm having issues with it. Can anyone guide me and tell me if its worth the hassle of doing it right or changing out the transmission
Number on the transmission is c-2605275
PostPosted: Fri Oct 25, 2024 4:11 pm
I have never even heard of it?
PostPosted: Fri Oct 25, 2024 4:30 pm
Post detailed pictures or links to high resolution pictures or a video of what you have.
PostPosted: Fri Oct 25, 2024 6:17 pm
This is all the pictures I have at the moment. The transmission number is c-2605275 i know it's a 4 speed and has a ford clutch.
PostPosted: Fri Oct 25, 2024 6:39 pm
Turns out the T170 is a Tremec 4 speed transmission used in late 70's to mid 80's Ford trucks and some cars. It is like our 833OD. 4 gears with 4th being overdrive.
PostPosted: Fri Oct 25, 2024 7:50 pm
It looks like a possible swap job.
The 4-speed hump for the 833 /Hurst shifter is there, s it probably had an 833 at one time.
PostPosted: Fri Oct 25, 2024 8:57 pm
Not sure if it is since that's all I could find from the number. I saw a older dodge pickup with slant six 4 speed transmission (it has the round headlight) with granny gears. Could I rebuild it and change out the gearing so it picks up alot quicker just like the trans that I have in it now.
PostPosted: Fri Oct 25, 2024 8:58 pm
They did a bad job at the swap
PostPosted: Sun Oct 27, 2024 11:13 am
The usual practice is to start out in second gear with the granny-geared trucks. Second gear is just like the first gear in other transmissions, with the granny-low provided for heavy towing, pulling stumps, starting on steep hills and in agricultural work where it is used to ease along through the field at idle while loading hay bales, sugar beets, etc.. Often, children were the designated drivers when harvesting and sometimes, when straddling rows in a big field, no driver at all would be aboard until approaching the end of a row.
A granny-gear with a slant six will out-pull most anything on the road. As you might guess, I like them a lot. I wish I had one. If you go with one, no rebuilding except maybe seal replacement should be necessary. I've never heard of anyone wearing one out, or tearing one up.
PostPosted: Sun Oct 27, 2024 1:20 pm
Would you recommend replacing with the one i already have than? How would I know if it has OD or not would I also be able to use the same shifter I currently have?
PostPosted: Sun Oct 27, 2024 3:06 pm
No you would need more than just the transmission if you switch to the granny gear transmission. The Bellhousing, flywheel, clucth, pressure plate are all different, and would need replaced as a set. The shifter on those transmissions is built into the top of the transmission. Your driveline would need a different yoke...etc. Not even sure that the floor pan above the transmission may be different.
You are almost always better to find a complete set up from a donor truck if you are trying to make a swap. Do you want or need the granny gear? I hate them because you basically have a 3 speed with a low gear so low as to be unecessary 99% of the time. Do you want to be able to cruise on the highway and have a OD gear, then the 833 OD is probably the way to go and likely what your truck had originally.
Any way you look at it all this stuff is 40 years old now and half of it is worn out. Good luck finding what you are looking for.
PostPosted: Sun Oct 27, 2024 5:38 pm
I don't need anything granny gears. And yes cruise on the highway with quick acceleration. How would I know if it's a 833od manual? There is a parts truck that's fully stock slant six with 4 speed. Not sure if it's granny or od guy told me it was a granny. I do know that the shifter is on the top but it's closer to the driver than in the middle
PostPosted: Mon Oct 28, 2024 5:43 am
Does the shifter hang off the side of the transmission or does it stick out of the top? 833OD have the shifter mounted onto the side of the tailshaft using an aluminum adapter bracket.
PostPosted: Mon Oct 28, 2024 5:50 am
I am not sure i would have to go and check. I'll post back when I find out
PostPosted: Mon Oct 28, 2024 6:05 am
Changing the transmission will not give you any more power and your acceleration will be close the same with the 833OD as what you have now.
Acceleration is most affected by the rear ratio or else having more raw HP.
