It is currently Wed Oct 21, 2026 11:51 pm
 Post subject: Rotating effort?
PostPosted: Wed Oct 30, 2024 9:05 am
Have any of you guys that are assembling your own engines ever checked the force needed to rotate the crankshaft with the bearings installed? I remember my only"professionally" built engine and how little effort it took to spin it. So I decided to check mine.
I am rebuilding my back up engine and just installed the crank and main bearings. Once moving it takes only 11-15 inch pounds to spin the crank. Not very much. Will do the same once I get the pistons and rod bearings installed. Just one more reference point.
 Post subject: Re: Rotating effort?
PostPosted: Wed Oct 30, 2024 9:59 am
Just the crank there should not be much of any drag on a straight main bore block.
The rings will be what add the most drag.
Until the valvetrain is installed.
PostPosted: Wed Oct 30, 2024 11:26 am
Yeah, I figured I'd just start keeping track a little and see what everything does when it is installed.
PostPosted: Wed Oct 30, 2024 12:04 pm
I remember with my K1/Wiseco setup for the 64 Dart motor it took about 6-8 ft-lbs to rotate it, before breakin and with no head, cam, chain... Your crank number sounds good.
Users browsing this forum: AdsBot [Google] and 26 guests
