It is currently Fri Jun 19, 2026 11:15 pm
Post new topic  Reply to topic  [ 616 posts ]  Go to page Previous 138 39 40 41 42 Next
PostPosted: Mon Dec 16, 2024 1:42 pm
You ready for the Daytona now too? :mrgreen:
C’mon widdit… :lol:
But only if I get the Turd back with it… :lol:
PostPosted: Mon Dec 16, 2024 2:49 pm
C’mon widdit… :lol:
I might be able to talk son in law out of the truck, but it might be a little spicy. It's got a 360 fo barrow moder in it now, with a rebuilt 727, and a Sure Grip unit in the rear, so major upgrades have been made.
PostPosted: Mon Dec 16, 2024 6:15 pm
I thought about trying to pry that truck loose but I now have 2 of them, no room for another
PostPosted: Sat Dec 21, 2024 4:43 pm
I got ToadRacer II home and cleaned out a couple or more decades worth of leaves, dirt, rust, etc.
It appears to have last been registered in 1971.
The odometer shows 48,xxx miles and there are service stickers in the door jamb that say the next service was due at 46,950 miles…
With the big hole in the windshield and sitting with the front of the car exposed, the rust in the floorboards is fairly significant. It doesn’t appear to be insurmountable or significantly structural at this point.
Once I get the Turismo carcass out of the way at the “other” shop I’ll get TR II up on some big jackstands and crawl up under it with a good light, a hammer, a pick, a screwdriver, and a beer… :lol:
I plan to deconstruct this car and gut it for a race car, so if anyone needs any interior hardware, etc let me know.
PostPosted: Sat Dec 21, 2024 4:47 pm
Put that basket on ebay! It may pay for your roll cage. Especially with a 50 year old broom! :D :D
PostPosted: Sat Dec 21, 2024 4:56 pm
:lol: :lol: :lol:
And the vintage shoes!
PostPosted: Sat Dec 21, 2024 5:01 pm
Rob, put up a parts for sale ad on FABO. One member over there parted out a 64 Cuda, and was getting requests for just about everything. Even small things. I got some parts for my Valiant, and I thought he had reasonable prices.
PostPosted: Sat Jan 04, 2025 7:35 am
Awesome Rob, she's clearanced for subframe connectors for You already!!! I bought a 170&PB trans out of a '62 just like that, which I had to remove Myself, they transported it from the barn on forks & bent the propshaft. I was afraid to even get under it, it was sagging mid ship ~4", luckily I brought the DeWalt reciprocating saw.....lol....looks like You've found the perfect successor to TR I, looking forward to the transformation!!
Jim K6
PostPosted: Sun Jan 05, 2025 11:35 am
Thanks Jim. I’ll post updates from time to time.
I had to roll it out of the shop for now while we pull the drivetrain and wiring out of a Camry to put in Pollywog (MR2).
We learned a couple things on ToadRacer that should make ToadRacer II even more betterer…. :mrgreen:
PostPosted: Tue Sep 30, 2025 2:51 pm
Adam and I met up and looked the car over last week. Nothing horrendously scary, so we will be moving forward with the build soon(ish)...
It's in the shop and ready for disassembly to begin.
PostPosted: Wed Oct 01, 2025 3:49 am
Hmmmm. Thanks for the update, Rob. Interested to hear more...
PostPosted: Wed Oct 01, 2025 7:47 am
I'll continue to post updates here. I likely won't have time to really dig into it until I get back from WyoTech next spring/summer. I might sneak over just a little during my week breaks in December and March.
There is some rust in the front frame rails and transmission crossmember areas... and we will need as much engine bay room as we can get, so... The plan is to stub the front and use something like a Mustang II front suspension. We talked to David Watkins to get some guidance on that so as not to fail tech.
We will be cutting the firewall and moving the engine back a healthy bit for better weight distribution.
We will cut the roof off and re-use the Pig Pen Fabrications roll cage from the original ToadRacer as well as the 8.8 differential.
There weren't very many other parts we could re-use, unfortunately.
Depending on how much time we dedicate to the build, we may shoot for a debut at Road Atlanta 2026.
More to follow...
PostPosted: Fri Apr 10, 2026 6:18 am
I need it out of the way and it was partially disassembled, so…
Debating about the way ahead…
Options:
1. Use ToadRacer I K member, brakes, steering, etc.
1a. Same as 1, but convert to coil overs.
2. Front stub frame with Mustang II set up.
3. Front stub frame with later(wider) A body or even B body. The wider the better to fit the set back Hemi planned for the build.
I have seen the Gen III Hemi in the early (narrow) A bodies, but it is very tight. The engine set back (18” or so) will make it even more interesting. Converting to coil overs to open up the torsion bar room is pretty much a given.
Or,… do I just slap it together the best I can with whatever ToadRacer I parts I could salvage and leave it at that…? :?
PostPosted: Fri Apr 10, 2026 6:21 am
The original engine is “Special”.
PostPosted: Fri Apr 10, 2026 6:28 am
Interesting questions, Rob... I'm a Slant guy and Mopar tbar suspension guy, so that gives you my answers.
Is that an aluminum engine with the SPECIAL head?
Welcome back to KY and the land of Simmons' Mopar Central!
