It is currently Sat Aug 15, 2026 11:41 am
PostPosted: Sun Dec 22, 2024 12:37 pm
When I do swap my 4 speed back into the car I was considering installing the later through bolt style of rear transmission mount in the car. I didn't know it if the later cross member is a bolt in or if I would just need to modify an early one to accept the later mount. The later capture mount just looks a lot more robust to me. So is this worth doing or should I just run what I got.
PostPosted: Sun Dec 22, 2024 1:14 pm
If you get a poly version of what you have it will be fine.
I have that mount in the Ruster with transbrake and I had it in the '69 Dart with slicks and 3400# car - Never gave me problems
If you want to swap to the spool mount, then I believe you will have to mate the spool to a new transmission member. I am not certain on this however.
Good Luck!
PostPosted: Sun Dec 22, 2024 3:47 pm
Every time I look at the single small bolt at the base of that mount I ask myself why. There is no reason it could not have had two bolts there or at least a larger single one.
Thanks Greg!
PostPosted: Sun Dec 22, 2024 4:41 pm
Greg's right. Assuming a good-quality part, even the rubber version of the stock pre-'73 vertical-shear trans mount is quite durable. They go for decades. Best spend effort-money-time elsewhere.
PostPosted: Sun Dec 22, 2024 4:50 pm
Possibly, But I won't be driving it like grandma's 100HP grocery getter either. :D :D Thanks for the opinions.
PostPosted: Sun Dec 22, 2024 6:38 pm
IIRC, the later spool mount crossmember will need some tweaks to make it work. Should be child's play for you.
PostPosted: Mon Dec 23, 2024 4:18 am
There is a 2 bolt version of that block mount too.
PostPosted: Mon Dec 23, 2024 4:02 pm
I was wrong.
The spool mounts were made in the 4 hole trans member.
Not sure of the changeover year.
Bolts went from 1/2"ø to 3/8"ø.
Not sure if the holes align up or if futzing nerds to be done.
PostPosted: Tue Dec 24, 2024 5:04 am
I'm a futzing nerd...
PostPosted: Tue Dec 24, 2024 7:25 am
:D :D
Yessir you are!
PostPosted: Tue Dec 24, 2024 9:02 am
I am pretty sure I am not smart enough to be a nerd, but I am a tinkerer! :D :D
PostPosted: Fri Dec 27, 2024 4:23 pm
Apparently I cannot type or spell.
You know that it is not AI generated. :D
Users browsing this forum: Amazon [Bot] and 1 guest
