It is currently Tue Aug 11, 2026 8:48 am
Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Aug 07, 2024 11:10 am
It takes seemingly forever for me to get results sometimes, but I always get results eventually!
FYI, I will be attending a science conference in Tromso, Norway in 3 weeks, and I almost got a flight with a stop in Helsinki. I also thought about trying to get a 1-3 day stop in Finland, but I was not able to do that. Someday, it would be great to meet you! Anyway, just letting you know I was thinking about that.
Cheers,
PostPosted: Wed Aug 07, 2024 12:29 pm
Car Model: 1966 2D Dart
You’re welcome when you have possibitity to come here. Pls inform before to confirm I am here;
We just finished one week mc tour where we ride Stockholm-Oslo-Stavanger-Bergen-Oslo-Stockholm loop.
PostPosted: Wed Aug 07, 2024 2:51 pm
Will do! No idea when this might come up again. Wow, that sounds like a great cycle trip!
PostPosted: Tue Aug 27, 2024 5:34 am
That should get you down at least 500 RPM and it should still be great up high. I would even go 216 LSA and maybe 214 deg @ 0.050" for a street car, or 218/218 and 116 LSA sounds about perfect. Leighton Drake used quite small cams (like the MP 244/0.436" cam) and still made 500 HP on a 225. I am going to try the Howards cam 214/214 with 0.450" lift and 112 or 114 LSA on a 225. On a 170 you should go wider on the LSA. Kenny Duttweiler (famous turbo V6 guy and Bonneville authority) recommended 116 LSA for Bob Dally's 170 bcuda with turbo.
Such a 218/218/116 cam now exist. I probably install it to somewhere 112 to 114.
I bought a used core cam with an oil pump it has been driving. If the pump looks okay I will use it. If not I will use the gear to the new pump. I dont need 6 bolt pump as I have a oil sprayer in the location of distributor. Ignition is made by waste spark six output coil.
PostPosted: Wed Aug 28, 2024 11:48 am
Cool! Good luck with the building and testing...
PostPosted: Wed Oct 23, 2024 9:37 am
As my garage season is just opened - I got other stuff out of it and autumn is going too cold for my E85 Dart - I am planning go and start the build.
My head is "blueprinted" to 58cc and the block has almost stock height - letters stamped from factory still exists. Pistons are "some brand" and just below the deck.
As I dont plan to run gasoline ever with this but just E85 should I mill the head a bit for compression increase? Something like 9-9.5. Still the 218-218-116 cam is pretty much wilder than stock.
PostPosted: Wed Oct 23, 2024 2:46 pm
I am not schooled in E85 usage. Maybe search internet for how much CR you might increase vs. gasoline on boost? I would probably stay at 8.5-9:1 myself, but again I have not researched this...
PostPosted: Wed Oct 23, 2024 11:52 pm
It is said "not pinging". The rattle heard is because parts are bending and cracking. Probably I keep what I have and just control the boost by ECU.
I am planned to set the cam to about same as the 224/224/110 was. Intake in between 106-110. So the biggest difference with the new cam is the exhaust lobe advance by the added LSA (116-110=6).
And I hope the factory cam core with factory pump gear will be better than parts I have had.
PostPosted: Mon Feb 24, 2025 2:49 am
First start with a new cam. As I have efi I found huge lambda value change at low vacuum. The map was build to make 1.0 at low vacuum but with a new cam I saw 1.3 or more. This mean that the engine get some 30% better fill at low vacuum with the new cam.
As we still have winter I cannot do remapping or roadtests yet. But what I did at the garage using brake I found boost at stall. Seem I have got good suggestions from you guys.
New cam is 218 @ 0,05” with 114 LSA. Old was 224 @ 0,05” and 110 LSA.
PostPosted: Mon Feb 24, 2025 5:00 am
That's great! You may not lose much (or anything) at higher RPMs, and building the boost down low will really help with ease/predictabtility of driving, and getting you off the line more quickly. I'm excited to hear about tests...
Best wishes,
PostPosted: Fri Mar 07, 2025 9:43 pm
Gear on, left foot on a brake pedal. Little throttling. About 2000 rpm. Still about 1000 rpm below stall. Manifold vacuum reads 77kPa.
But what happens in a tube from turbo to the throttle blade? There is already 110kPa and this is far below from stall!
Sadly it is too early for road tests. But this a quite promising.
PostPosted: Sat Mar 08, 2025 3:12 am
Yes, looks promising. Must be only a tiny throttle opening. I have never looked/tried a MAP sensor upstream of the throttle, and that is a great idea.
What type/brand/size turbo do you have on there again?
PostPosted: Sat Mar 08, 2025 11:32 am
T3/4 ”hybrid” from a brand Maxxspeedingrods. Was listed for 1,5 - 2,5 liter engines. It was cheap but the quality was surpricing good EXCEPT…
The original wastegate actuator was not good. Lucky me I had protective shut down at ecu. It took power down at 200 kPa where the boost went immediately at apprx 4000 rpm.
I tried to tune the original actuator with few external springs:
That spring outside of actuator reduced the operating point and was adjustable.
I found possible to do that but I got it better result after purchasing a Mamba actuator with a set of different springs. Mamba actuator cost more than that cheap turbo. There was still some unattended boost increase at high rpm 6000+ so I ported the waste gate hole inside the turbine from 16mm to 19mm and rounded the hole opening.
Later I bought an extra soft spring (0,5-0,7 bar) to actuator. That was used at the test for power output. Test was a must for the inspection of the car. The turbo is now street legal as the power output is not too high.
Bit later I made an active control for the boost by ecu. That system is my own design with a restricted leak controlled by a Burkert proportional valve. The control system is ”open loop” like an old style ”turbo screw” but is tuneable from ecu. No adjustable screws anywhere.
I have this kind of table for the proportional valve PWM and I can get set the max boost stepless from the actuator nominal pressure ”to as high I like”. No need to change parts for adjustment.
That valve get also the turbo spinning faster than without.
I have used that same style pressure control system in my Sportster. I keep it normally at 0,5 bar but for fun I raise it to 0,8 bar,
PostPosted: Sun Mar 09, 2025 3:03 am
Sounds cool. Interested to hear about road tests when you have good weather, etc.
PostPosted: Mon Apr 28, 2025 5:02 am
As the spring did not seem ready to come here I went south to find it. I shipped my Harley to Spain. Flied myself there and rode the bike to north Germany from I took a Ferry. So across Europe trip was done within less than 3 weeks total. Very nice trip with no rain at all from Fuengirola to Travemunde for why I was on the road about 3400 km.
After couple of days relaxing from my tour I decided to took my Dart out of the garage. I have found a huge difference of VE adjustment needs when in deep vacuum - engine effeciency improved at low load. However the turbo is not very much improved spooling at low rpm. And that was the main target. Probably I get better mileage now but not so much tire spins I was waiting for.
Any ideas? What about removing the muffler from exhaust to get less restriction? Probably not as the exhaust pipe doesnt restict high rpm power a much. More ignition advance to 3k area? More fuel to 3k area?
