It is currently Fri Nov 13, 2026 9:23 pm
Post new topic  Reply to topic  [ 46 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Mar 30, 2024 3:59 pm
Sounds great, Matt.
PostPosted: Sat Mar 08, 2025 3:59 pm
Car Model: 1966 Dodge Dart
This project has been sleeping for a while, but it's about to pick up again. I will have a few ready to beta test this week and they're not all spoken for. Let me know if you're interested. These are directly meant to plug into a wiring harness intended for a dual field alternator.
Matt Cramer
PostPosted: Sun Mar 09, 2025 3:00 am
I'm in for at least one.
PostPosted: Sun Mar 09, 2025 11:59 am
I will try one out. Let me know what is required.
PostPosted: Wed Mar 12, 2025 4:22 pm
I have one prototype up for grabs - if you are able to test it on a dual field regulator quickly, let me know!
Matt Cramer
PostPosted: Sat Mar 15, 2025 4:09 am
And here's what the prototypes look like. Production ones will be all black.
File comment: Prototype regulator
Matt Cramer
PostPosted: Sat Mar 15, 2025 4:40 am
Matt I can test it on my truck if you like
PostPosted: Sat Mar 15, 2025 12:57 pm
I think one of the guys on FABO called dibs on it, but I'll let you know if he doesn't follow through.
Matt Cramer
PostPosted: Sat Mar 15, 2025 6:48 pm
Sounds Good Matt!
PostPosted: Sat May 10, 2025 6:49 am
These are now green-lit for production! Estimated ship date for the production batch is sometime in June.
Matt Cramer
PostPosted: Sat May 17, 2025 8:39 am
Working on a catalog listing: https://cramerpower.com/products/adjust ... e-plymouth
Matt Cramer
PostPosted: Sat May 17, 2025 11:31 am
Nice web site, Matt!
I think you've got a good thing going!
– Eric
PostPosted: Mon Jun 02, 2025 3:58 pm
Got a message from the contact manufacturer that one component is running late, but not by much. I'm going to push the release date back to sometime July 2025.
Matt Cramer
PostPosted: Wed Jun 25, 2025 3:16 pm
Encountered some production snags and the initial release is going to use a conventional circuit board with a generously-sized heat sink on the main power transistor instead of the aluminum PCB / integrated heat sink construction. Still on track for a July release.
Matt Cramer
PostPosted: Wed Jun 25, 2025 5:18 pm
Hey Matt, mine is still working fine. About 800 miles driving on it so far. :D
