It is currently Fri Nov 13, 2026 10:40 pm
PostPosted: Thu Apr 17, 2025 1:40 pm
Need to connect my electronic Actron tach to do some carburetor and idle speed adjustment fine-tuning. In the past, you’d hook one tach lead to the ignition coil negative terminal (if memory serves). But since that time, I upgraded the ignition to the GM HEI setup and now I’m unsure where that tach lead gets hooked. I followed the excellent HEI conversion procedure write up from SSDan on this site.
Who can tell me where it goes now?
PostPosted: Thu Apr 17, 2025 1:53 pm
Car Model: 78 aspen
terminal b on the coil. there is an excellent picture in dan's article
PostPosted: Fri Apr 18, 2025 9:41 am
Thank you. I haven't re-read that article in awhile.
PostPosted: Fri Apr 18, 2025 10:47 am
Car Model: 78 aspen
you're welcome.
i kinda thought you might have not gone back lol
