It is currently Fri May 22, 2026 5:15 am
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 176 77 78 79 80 81 Next
PostPosted: Sun May 18, 2025 9:24 am
Could the ladder bar length be that far off side to side to cause a hard right launch? I honestly know nothing about ladder bars or 4 links. :?
PostPosted: Mon May 19, 2025 8:53 am
Left bar too long or right bar too short. Rear end isn't square under the car.
PostPosted: Mon May 19, 2025 10:29 am
Both bars are exactly the same length, Hemi joint to clevis.
Now it might not be square but the bars are the same.
PostPosted: Mon May 19, 2025 11:39 am
I found the Problem!
You never swapped out the Hemi Joint for a proper Heim Joint.
:D :D
Good luck sorting it.
PostPosted: Mon May 19, 2025 11:53 am
Agreed. Should be a 1/2 hemi joint, not a hemi joint. :P
PostPosted: Mon May 19, 2025 12:50 pm
You guys are smoking joints.
PostPosted: Mon May 19, 2025 2:34 pm
But their cars go straight.
PostPosted: Mon May 19, 2025 3:49 pm
Glad someone said it.
Smokin' Joints? I don't think so.
Tires in the burnout box? Well, possibly.
:D
PostPosted: Mon May 19, 2025 7:10 pm
That means absolutely nothing. :oops:
PostPosted: Tue May 20, 2025 8:53 am
Sounds like maybe a 4 wheel alignment is in your future? :D
PostPosted: Tue May 20, 2025 9:19 am
Not getting much help from the peanut gallery.
Some are helpful.
PostPosted: Tue May 20, 2025 10:09 am
What would be nice would be if you could find someone with a vacant parking lot or something, where you could go and make a lot of back to back adjustments and launches without having to go to the track. At the track you only get 2 or 3 runs and wait for 3 hours and still may not find an answer. I wish I was of more help, sorry! :)
PS How long is your garage? :mrgreen:
PostPosted: Tue May 20, 2025 1:25 pm
Not that long Rick!
I will get it.
PostPosted: Tue May 20, 2025 2:00 pm
Seeing if the housing is square in the car doesn't take a degree in rocket surgery. It's not like you're launching a probe to Mars. : :mrgreen:
PostPosted: Wed May 21, 2025 5:47 am
Stan, I bought this book years ago.
Not sure that I really remember anything from it, but If you do not have it, It could prove helpful. It's on my shelf for reference and re-reading when I need it.
Like I said before I never really had any of those problems with either the '69 Dart ~3400# stick car or Ruster ~2200# Foot brake / Trans brake car.
