It is currently Sat Aug 23, 2025 10:20 am
PostPosted: Wed May 28, 2025 10:45 am
Looking for 1 bbl carb. Cant seem to find new old stock. Tired of replacing china versions every year o so
PostPosted: Wed May 28, 2025 1:33 pm
What year is your D150? Does it have a manual or automatic transmission? Is it a 49-state, California, or Canada-spec truck?
PostPosted: Wed May 28, 2025 4:03 pm
83, manual 49 state
PostPosted: Sat Jul 19, 2025 5:25 pm
If I have to do some extra mods to make it work im fine wuth that.
PostPosted: Sun Aug 10, 2025 3:56 pm
Car Model: A couple slant six mopars and other mopars
https://www.carburetion.com/Products/Pr ... ?Part=UNV1
Product Details:
Universal Daytona Model 1904 1 BBL
Bolt pattern center to center 2 5/16 - 2 11/16 4.50 tall - Adjustable main jet works on 4 and 6 cyl - 180 deg adjustable linkage
Product Application:
Applications: Universal Carburetor 1 bbl Replacement for Holley 1940 1904 1920 Autolite 1100 1101 Carter YFA BBR1 BBS RBS Rochester Monojet
Manufacturer Info:
Manufacturer/Distributor : Daytona
Manufacturer Part Number : UNVDA1904
$350
I just bought a $85 2bbl off ebay. It looks good, have it mounted but haven't fired up the car yet.
Wonder if a 1BBL for a Ford six would work? its $89
https://www.amazon.com/Waverspeed-Carbu ... 9665&psc=1
PostPosted: Sun Aug 10, 2025 4:28 pm
Nope. That one won't come close to working on the OP's truck. It lacks numerous necessary hookups, the linkage configurations are wrong, the air cleaner attachment is wrong, etc. Seller's promotional claims for it being a "universal" item are severely exaggerated.
Those Chinese 2-barrel BBD knockoffs won't work for the OP's 1-barrel application. Whether they'll work passably well in a 2-barrel application is luck of the fates.
No, different mount pattern and hookups, etc.
PostPosted: Sun Aug 10, 2025 4:52 pm
THIS would be near the top of my list of candidates.
As would be THIS and THIS and THIS
Don't be afraid to disassemble them, soak them overnight in carb cleaner, maybe give them an ultrasonic treatment, and rebuild them. I would rather spend the time carefully rebuilding a true junkyard core, including rebushing the throttle shaft, than roll the dice with a Chinese knockoff or repair warehouse unit.
PostPosted: Mon Aug 11, 2025 12:58 am
What would be a good rebuild kit?
PostPosted: Mon Aug 11, 2025 12:26 pm
Walker 15560D
