It is currently Sat Oct 24, 2026 12:50 pm
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu Sep 25, 2025 1:32 pm
I agree with Dan. Johnny/Polybushings is a good way to go. They will not be cheap, but will work forever. Good idea to get a softer compound.
PostPosted: Sat Sep 27, 2025 12:31 pm
You can certainly buy that garbage from RockAuto (or any other source), if you want to have to do the job again soon.
Write to Johnny @ Polybushings and see if he'll make you a softer-than-usual set of the 2303-2304 mounts.
Thanks SlantSixDan, I'll follow your input.
Maybe a stupid question since I am the kind of person that asks when a bolt needs to be tight, 'how tight (Nm / torque).
What is a definition of 'softer than usual set' and the 2303-2304 mount? I have no idea what that means.
PostPosted: Sat Sep 27, 2025 3:28 pm
I think Johnny uses 70-durometer material for those mounts usually. Ask him what the options are for a material that is softer than 70. Tell him you want isolation characteristics similar to the original mounts, but the durability and build quality of his polyurethane ones.
PostPosted: Fri Oct 24, 2025 9:06 am
I got a response that the mounts are 70 duameter and that is the softest there is. I have ZERO idea if that is fine or not. I assume if Johnny is the way to go, then I shouldn't be asking any more questions
PostPosted: Sat Oct 25, 2025 9:05 am
They may have a bit more vibration than stock, but they will never wear out or break. Otherwise, it is a crapshoot on what you get with "new" or "NOS" parts.
PostPosted: Mon Oct 27, 2025 2:30 am
well the car is not shaking at all, at the moment. it is running so smooth and well adjusted that you don't notice the car running when running stationary (warm engine).
it is only when I start to drive, the engine tilts too much so there is a metallic sound, only on driving away with the most torque, when I press more on the accelerator the sound is gone.
PostPosted: Mon Oct 27, 2025 10:37 am
You need new motor mounts, as a priority. This what you describe indicates yours are worn out. This is a serious safety hazard, as well as being bad for many parts of your car. Make a thoughtful decision about what mounts to buy, and go forward with it.
PostPosted: Tue Oct 28, 2025 4:47 am
they are already on their way over the pond :wink:
PostPosted: Tue Oct 28, 2025 5:25 am
Contributor
In my case this is a damned if you do and damned if you don't.
When I restored and rebuilt all the suspension and drive train parts on my '64 Valiant convertible about thirteen years ago, the only mounts I could find were Anchor. For a few years they were okay, but eventually they began to "mush'. About a year ago, I ordered a set of Poly mounts from Johnny and had a respected local shop install them. When I started the engine and it dropped to idle speed, I was horrified by dozens of rattles and vibrations I'd never heard before! Everyone said it was normal for poly, and that the new noises would lessen as they broke in. They did lessen somewhat, but I'm embarrassed to sit at a stop light and share the vibrating noises with cars around me that are staring at the neat old convertible. No way will I offer a ride to anyone I wanted the car to impress!
Now, I'm in a quandary. I really dislike driving the car the way it is, but I'd hate to buy Chinese replacements to put it back the way it was. Even if I did go with the foreign parts, I'd have a hard time getting them installed since my local shop was kind enough to install the ones I have now and said they were not interested in working on my obsolete cars again. Since I'm eighty-four-years-old, there are some projects I simply can't do anymore, and regular repair shops won't touch a car the age of mine. The only restoration shop around here apparently doesn't have anyone with Mopar knowledge, and their prices are sky high. The one time I asked them to help me locate a low growl in the driveline, they said they couldn't hear it and after the "fine tuning" they did on the carb and timing, I drove home and reset it by ear so it would start and have normal power,
I don't want to disparage Johnny's product in any way. He was totally above board about poly issues, and the product looks as professional as any big company could produce. The hobby needs more guys like him to keep it going!
I just wanted to share one frustrating experience from an old man who should probably grow up and forget past loves.
PostPosted: Tue Oct 28, 2025 6:01 am
well no way back now... I really want the car to be as smooth as can be. Now regretting to buy these. But the rubber versions are widely available but everyone keeps telling me it is rubbish that you buy...
https://www.partsgeek.com/catalog/1964/ ... mount.html what's wrong with these then?
plus... they will not be shipped overseas...
PostPosted: Tue Oct 28, 2025 7:11 am
Firmer motor mounts don't cause rattles. They cause an increase in vibrations. The rattles are caused by loosely attached/flexing parts that vibrate with the increase in vibrations. Have you considered addressing the parts that are transmitting the noises themselves. The softtop cars are quite a bit more flexible so I would always expect a bit more rattling than the sedans/hardtops.
Changing your exhaust hanger system and adding a flex joint can go a long way to decreasing noises. The solidly mounted exhaust systems are basically a sound tube that is 11 feet long. The commonly used cheap hanger don't have very much room for movement/dampening. here is an example of what was common on old cars and another that is used on almost every modern car.
https://www.amazon.com/Exhaust-Hangers- ... d22cc1fcdd
https://www.amazon.com/Exhaust-muffler- ... 53b69&th=1
Adding some mass loaded vinyl in key locations or a good butyl sound deadener(dynamat) also makes a huge improvement.
Check to see if you the seam sealer that "glues" your hood skin to its support braces has dried out and cracked. That hood panel will make a huge amount of noise when it is no longer secured to its supports, it basically becomes a drum the size of your hood.
My daily driver for the last 6 years has been a late 90's manual trans honda CRV. These early crvs were not known for good NVH. Mine is quiet entirely because I took the time to address the issues the factory didn't. Now if I drive a similar CRV I remember the time spent because the difference is very obvious immediately.
Having firmer mounts is not an impossible challenge to overcome. Sounds like you need to adopt a neighbor kid/nephew/grandkid that wants to learn and help.
PostPosted: Thu Mar 26, 2026 6:03 am
finally got them installed (not by myself but a mechanic for classic cars) and they are too thin... only way to get them mounted right is with spacers in between...
PostPosted: Fri Mar 27, 2026 1:11 pm
That's…odd. I've never seen such an issue with those mounts. Are you quite certain you ordered and received the correct mounts, and they were installed correctly?
PostPosted: Fri Mar 27, 2026 1:20 pm
»Zonk!« This is a great idea! I wish it had occurred (or been suggested) to me years ago.
Could also make it much easier to have a new headpipe made – doing it all with rigid pipe poses difficulty with that tricky first curve/bend below the manifold outlet. It used to be common advice (when the wrecking yards were full of Slant-6 cars) to take the first ~foot of headpipe from a '77+ / Super Six so as to obtain that bent part, with the right curve and the flange at the correct angle/orientation, then let the exhaust shop weld onto that pipe.
To put in a flex, I imagine buying or make something that looks like this, then go rearward from there. I'd want to delete the headpipe-to-bellhousing clamp (if present), so as not to re-transmit engine vibration to the pipe below the flex.
What-all did you do? My '14 Mazda 6 is also a model known for being not very quiet inside.
PostPosted: Fri Mar 27, 2026 3:47 pm
Mine for my 65 Valiant were taller than the soft crushed rubber ones I took out. (They were actually where they should have been all along) I can't imagine yours are correct if they are too short? That seems odd to me.
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
