It is currently Fri Jul 17, 2026 11:32 pm
 Post subject: 7 1/4 and 8 1/4 ID
PostPosted: Tue Dec 14, 2004 4:02 am
:?: Hi,
I'm sure this has been addressed here before but I'll ask anyway.....
How do you tell the difference between a 7 1/4 and an 8 1/4?
Would the build sheet ID which rearend you have?
Thanks
Todd
PostPosted: Tue Dec 14, 2004 7:23 am
7.25" - small, more angular cover, 9 attaching bolts.
8.25" - larger, round cover, 10 attaching bolts.
8.75" - (you didn't ask) ring and pinion center section ("chunk", "pumpkin", etc.) bolts up from front, rear cover integral with axle housing.
D/W
If it ain't broke, fix it!
PostPosted: Tue Dec 14, 2004 9:17 am
<img src="http://img.photobucket.com/albums/v514/Slanted_Mind/MoparAxles.jpg" width=400>
-S/6
PostPosted: Tue Dec 14, 2004 10:37 am
...that's pretty handy, but a footnote should be added that most older 8.25 axles have a rounder cover than pictured.
D/W
PostPosted: Tue Dec 14, 2004 10:58 am
I forget where I ran across that photo, but knew I could use it someday. :)
I'll see about adding a note for the earlier axles if I can.
-S/6
PostPosted: Tue Dec 14, 2004 11:12 am
So, is an 8 & 3/4 a good one?
That's what it appears I have under my van.
Later,
Dan
"I may be slow, but at least I'm not very fast!"
'69 A108 - 225, 727, 3.55, MSD6AL, a.k.a.-the brick
PostPosted: Tue Dec 14, 2004 11:34 am
99.999% chance you will never break an 8-3/4 with a slant. :)
-S/6
PostPosted: Tue Dec 14, 2004 11:36 am
Awesome!
Hey, I just noticed that you and I joined this forum a year apart!
Later,
Dan
Oops! LOL guess it would have helped if I had looked at the month! LOL
PostPosted: Wed Dec 15, 2004 3:28 am
Thanks for all of your replys!
Looks like my 66 has the 7 1/4.
Todd
