It is currently Wed Nov 25, 2026 9:14 pm
PostPosted: Tue Jan 11, 2005 6:50 pm
about these cams?
would the 264 be better than the isky 264
Cam Chart Column Key
1 Part Number 2 Grind Number 3 Int. Duration (Gross) 4 Exh. Duration (Gross)
5 Int. Duration (.050") 6 Exh. Duration (.050") 7 Int. Valve Lift 8 Exh. Valve Lift
9 Lobe Separation 10 Int. Valve Lash 11 Exh. Valve Lash 12 Matching Component Kit
Mopar 170/198/225 6 Cyl. - Solid
1 2 3 4 5 6 7 8 9 10 11 12
14510 132F 264 264 224 224 .480" .480" 110 .014" .014" 44585
14500 137F 274 274 226 226 .480" .480" 110 .014" .014" 44585
PostPosted: Tue Jan 11, 2005 9:58 pm
How "good" a cam is depends on what you want to do with the engine you install it in. Go get groceries? Haul a trailer? win 1/4-mile drag races? win endurance races? Something else?
PostPosted: Wed Jan 12, 2005 8:50 pm
In my younger days, I had a 71 Demon with a 360 and a huge cam, 3500 stall converter, holley 850, forged pistons, etc..
I forgot about the gearing (it was probably 2.73)
The car was a dog.
I ended up selling it cheap to some kid in frustration.
What I've finally figured out is that everything has to work together as a package depending on what you want to do with the car (and how much you want to spend).
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
