It is currently Sun May 17, 2026 11:48 pm
PostPosted: Sun Jan 30, 2005 2:45 pm
Hey all, what year A body is the Large Bolt Pattern 7 1/4 rear found in? What other year/body cars do I find it in that will work in an 68 a body?
Thanks!
'68signet
"Living analog in the digital age."
PostPosted: Sun Jan 30, 2005 3:05 pm
'73-up all A-bodies with front discs, plus some '74-up A-bodies with 4-wheel drums. On a drum brake car, measure to make sure.
Also be aware of the rear axle ratio and its effect on your car's performance (and your speedometer!).
PostPosted: Sun Jan 30, 2005 7:24 pm
9" front drums=SBP until 76
10"front drums=BBP 73 until 76
PostPosted: Sun Jan 30, 2005 8:23 pm
Not always! The "birthday cake" 10-inch drums were SBP at least through '74, and I've seen 'em on '75s, too.
PostPosted: Mon Jan 31, 2005 4:00 am
take your tape measure with you is the best advise. I personally have never seen 10" brakes with SBP but I havent seen it all yet.
 Post subject: I seen it...
PostPosted: Mon Jan 31, 2005 4:50 am
66Dart has a set of 10"SBP drums on his car at the moment...
PostPosted: Mon Jan 31, 2005 9:52 am
Definitely true.
Assume you mean you've never seen 10" SBP brakes on a post-'72 car. 10" drums were first available on A-bodies in late '64, and they were all SBP until '72. It's in '73 that LBP brakes started appearing on A-bodies.
PostPosted: Mon Jan 31, 2005 1:10 pm
my 73 dart has 10" sbp front drums. :(
PostPosted: Mon Jan 31, 2005 3:17 pm
I stand corrected.
Yes I did mean 73 and up 10" drums ( I have 10" SBP on the rear of my car now on the 8 3/4)
