It is currently Sat Nov 28, 2026 10:30 am
 Post subject: Carb restoration?
PostPosted: Wed Feb 09, 2005 10:35 am
Car Model: 1962 Lancer 770
In my quest for dual carter BBS carbs, I didn't realize there were two different venturi bores and my otherwise perfect set wasn't so perfect. So I'm getting some other ones that I need to try and rebuild and wanted to know how I can get all the rust and crap off of this one. I have some carb dip, but figured I might need more than that to bring this sucker back to life.
Advice?
Here's the beast:
Thanks!
MJ
PostPosted: Wed Feb 09, 2005 12:06 pm
First step = strip it down and dunk it in the carb dip. Then you can clearly see what you've got to start with.
PostPosted: Wed Feb 09, 2005 12:29 pm
Sounds good. We'll see what it reveals. Thanks!
MJ
