It is currently Wed Nov 18, 2026 1:04 am
 Post subject: auto floor shifter
PostPosted: Sat Feb 19, 2005 2:55 am
getting an B&M star shifter, in the instructions, its said to lock the locking mech in the engine compartment, so that you can get the key in and out in the lock position. How is this done? I mean where is this done? I have a service manual and cant seem to find where to do this....thanks
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
PostPosted: Sun Feb 20, 2005 6:25 am
I assume you are converting a column shift car to floor shift, right? On a Mopar there is no locking mechanism other than securing the column shift into Park. I did the one im my Duster by taping the steering column so the shift tube wouldn't move after I took out the shifter handle. :shock:
PostPosted: Mon Feb 21, 2005 1:18 am
thanks Slantzilla...guess I will be taping the shifting tubes too..Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-70 cuda 383
PostPosted: Mon Feb 21, 2005 6:44 pm
If you lock it into park, you won't be able to turn the wheel.(If it has the ignition switch on the column)
PostPosted: Mon Feb 21, 2005 8:28 pm
Only when you shut the key off. :shock:
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
