It is currently Wed Jun 17, 2026 8:41 pm
 Post subject: Chrome Valve Covers
PostPosted: Fri Mar 11, 2005 8:35 am
My 65 Valiant currently has a chrome valve cover on it, but its quality leave a lot to be desired. Pitting and keeping the flash rust at bay is a never ending problem. I see lots of them on ebag. Can one of you recommend a source of a good quality cover?
PostPosted: Fri Mar 11, 2005 8:36 am
Car Model: 1962 Lancer 770
I don't know where to get a "good" one. The ones on ebay for $30 are crappy according to many that have used them (see: http://slantsix.org/forum/viewtopic.php?t=12121). I'm just going to paint mine chrome ;-) KIDDING! :lol:
PostPosted: Fri Mar 11, 2005 8:46 am
Gee, I was thinking Rhino Liner ... :lol:
PostPosted: Fri Mar 11, 2005 8:52 am
You don't "get" a good quality chrome valve cover, you make one. Pick out an original valve cover in nice condition and send it in for chrome plating. It'll probably be more expensive than buying an Offenhauser aluminum cover.
PostPosted: Fri Mar 11, 2005 3:16 pm
Youre obviously picking form over function here, but keep in mind chrome engine accessories retain heat....
PostPosted: Fri Mar 11, 2005 3:18 pm
I seriously doubt you'd be able to find any significant difference in heat retension even if your oil pan, timing cover, valve cover, oil cap, PCV valve, air cleaner and radiator top tank were all chromed compared to painted.
PostPosted: Fri Mar 11, 2005 3:50 pm
Car Model: '23 T-bucket
HMMMPH!! Chrome=bling! Lotsa chrome=bling-bling! :x None of it will help you go faster.
Roger
PostPosted: Fri Mar 11, 2005 4:42 pm
chrome dont get you home
PostPosted: Fri Mar 11, 2005 4:50 pm
yeah but you look good on the side of the road...
PostPosted: Sat Mar 12, 2005 10:32 am
Car Model: Valiant V200 225 4dr three on the tree
:lol:
Like an old man said; If it dont run, chrome it!
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
 Post subject: chrome crap
PostPosted: Sat Mar 12, 2005 8:05 pm
I just had to sand and paint my Edlebrock air cleaner and breather cap because of constant rusting. Even after waxing them a few times still rust. And Edelebrock is supposed to be good stuff. Save yourself some grief. paint your slant and its accessories a cool color. Remember, you can't shine a turd.
There is no problem that cannot be solved by the proper application of thermo nuclear weapons
PostPosted: Sat Mar 12, 2005 8:37 pm
Did you know that slant six water necks are aluminum? Water pumps too. Stamped steel shines up pretty nice, and cast iron may as well. Someday I want to try snad blasting and polishing all the stock pieces of a slant and then powder coating it with a clear coat and see how close to shiny chrome stuff it can look. As said above, chrome retains heat, and I don't like that. But a factory stamped valve cover sandblasted and polished would look just as good as a chrome piece and work better....
 Post subject: Re: chrome crap
PostPosted: Sun Mar 13, 2005 8:26 am
Yeah you can, if you rub it rigorously enough, but it still stinks! :shock: :lol:
D/W
If it ain't broke, fix it!
PostPosted: Sun Mar 13, 2005 9:52 am
Image I dont wanna know how you found that out...
Users browsing this forum: Amazon [Bot] and 2 guests
