It is currently Sun Jun 14, 2026 11:15 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3
Would you buy a significantly upgraded engine mount system for your '62-'66 A-body?
Yes 62%  62%  [ 13 ]
No 14%  14%  [ 3 ]
Maybe (please explain) 24%  24%  [ 5 ]
Total votes: 21
PostPosted: Thu Mar 17, 2005 2:09 pm
As soon as you defeat the mount by using a steel mount, you are not only transferring damaging vibrations to the front clip, you are also inhibiting the front clip's ability to flex independently of the very rigid engine/transmission (a point I should have made earlier).
Standard race car practice is to make the engine/transmission a rigid part of the chassis. If there was such a problem as you state, then I would have to believe that the various sanctioning bodies would have outlawed the practice many years ago for saftey concerns.
I just dont see any logic in risking so much to save so little.
And I believe you are making a big "todo" about nothing. As I have stated; I have run steel motor mounts in cars past, I did not experience the problems that you have raisen. Nor did my cars rattle apart and I still have all my teeth firmly afixed in my jaws.
Would I run them again, maybe, if the need was warranted.
"The new spool-type engine mount system offers much better control over engine movement compared to the 1972 sandwich-style mounts; roll is now limited to 3°."
——1973 Chrysler Corp. engineering overview
Really, all the engine with the new style mounts that I have observed, have more then 3* of movement. But then they are all over 30 years old now.
PostPosted: Thu Mar 17, 2005 3:17 pm
You know what kevin, just do it.
The thing will run without it, the mount wont break off, no binding/smacking when you launch full bore from a stoplight because you resent being passed. But that's it; that's the limit of the 'benefits' you'll receive from re-designing the Chrysler engine compartment, because that's what you're doing; you've told generations of superbly qualified engineers to stick it in their ear, you know a better way to do it. Of course, all the experts in the HOT ROD/Musclecar books say solid mounts are a wizard idea, along with super coils and yellow wires itty-bitty fan pulleys and all the other bitchin' tricks that made them rich and famous as builders of fine automobiles. What? Oh.
You are right though; those cracks arent magically going to appear overnight because you launched hard once, or twice, or three times. So feel free to do it your way and in a few years when you quietly discover said cracks and take your car to a welding shop to have it fixed, we'll all turn our heads and pretend not to see a thing. It's just easier that way
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 2 guests
