It is currently Thu Jun 18, 2026 12:00 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
Would you buy a significantly upgraded engine mount system for your '62-'66 A-body?
Yes 62%  62%  [ 13 ]
No 14%  14%  [ 3 ]
Maybe (please explain) 24%  24%  [ 5 ]
Total votes: 21
PostPosted: Tue Mar 08, 2005 12:30 pm
I've just been talking to Schumacher about the possibility of an upgraded engine mount system for the '62-'66 Valiant, Lancer, Dart and Barracuda cars (including Australian Valiants and Utes of these years) equipped with slant-6 engines. He's interested in designing and producing such a setup, and with this poll I'm gauging the interest level.
The system would replace the willowy biscuit-type mounts with the much stronger and better '73-up Mopar spool-type mounts. The spool type mounts allow much less engine "shift 'n' drift" and shake, while still isolating engine vibration so it doesn't shake you off the driver's seat. Various mount materials (rubber, hard urethane, soft urethane) are available.
The conversion package would probably cost around $150, same as Schumacher's other mount kits, and quality would be similarly high.
So...
PostPosted: Tue Mar 08, 2005 2:06 pm
Contributor
Great minds think alike! I proposed that exact idea to Schumacher about a year ago and they said they would look into it. Now that they have a second request, they might be more interested.
Yes, I would gladly pay $150 for the later model mounts and then the restorers can have the few stock mounts floating around the world.
PostPosted: Tue Mar 08, 2005 4:01 pm
I think $150 is a little expensive for a couple of brackets and two motor mounts.
PostPosted: Tue Mar 08, 2005 4:18 pm
Well, I don't work for $0.00/hr, and I bet you don't work for $0.00/hr, so it's a fairly good bet that Schumacher doesn't, either. Proper design and careful fabrication for a bolt-it-on-and-go operation is worth money.
Lots of ways to do it wrong or "almost kinda sorta mostly right"...
PostPosted: Tue Mar 08, 2005 5:04 pm
True, but $150 worth? After the initial mockup and the patterns are made, don't you think the "minimum wage" person will be doing the assembly?
PostPosted: Tue Mar 08, 2005 5:07 pm
That's possible. I don't know how many employees (if any) work for the head honcho. Still and all, if the options are "Available at $150" or "not available", I'll take option A...
PostPosted: Tue Mar 08, 2005 7:14 pm
Will these mount work on the 67 - 72 a bodies too??
Or are these yet a diffrent mount system from the 62-66.
PostPosted: Tue Mar 08, 2005 8:13 pm
Different brackets for '67-'72, but those cars have lots more existing engine mount options.
PostPosted: Tue Mar 08, 2005 8:40 pm
That price is way to much for me. I would spend my $150 on a disc brake rear end...or new carpet,,,,new (used)leather buckets....MegaSquirt...
Hell my 5 speed cost $125
My disc brakes cost $100
My Cressida buckets $60
Mags and T/A radials $100
Motor mounts,,,,, I bid $40,,,,just me...Im cheap
PostPosted: Tue Mar 08, 2005 9:56 pm
I have bought some products from schumacher and they are top quality and nice materials (no cheap stuff, I mean) still I think that 150 bux are a li'l bit pricey. I'd buy that w/o any hesitation @100 bux. 150 seems kinda "we-f-u-c-k-you-for-willing-to-stubbornly-stick-with-your-slant" price
anyways, there are new K mambers out there? please, online sources. My K member has developed some crack and I'd like to replace it.
Juan Ignacio Caino
PostPosted: Wed Mar 09, 2005 9:07 am
New K-members are going to be tough to find, but good used ones and even specially reinforced ones are available. You may want to take the opportunity to go to the '73-'76 (in North America) style K-frame, which is already set up for the spool-type mounts.
Now let me see...where did I see those reinforced K-frames...H'mmm....
PostPosted: Wed Mar 09, 2005 10:47 am
Count me among the many 8)
Troops on the battlefield have a far better view of the battle then the generals who lead them
PostPosted: Wed Mar 09, 2005 1:06 pm
Personally, I see this really as a high performance item. I have seen no overwhelming troubles (occasional split apart of rubber from metal - normal with age) with 62-66 engine mounts until the buildup gets fairly wild, and even then, they are livable. But, if you want make HP, especially with a stick and good clutch, reinforcement would be good.
PostPosted: Wed Mar 09, 2005 1:55 pm
Contributor
For many of us, it's a matter of getting a part. I've been looking for a right side mount for a year.
PostPosted: Thu Mar 10, 2005 1:58 pm
If that is a problem, then steel motor mounts will fix the problem. And anybody with a welder can make those for the cost of the steel.
