It is currently Sun Dec 28, 2025 7:11 pm
PostPosted: Wed Apr 06, 2005 12:29 am
i need help trying to looking for a distrubutor cap and rotor for my car.. A salesmen at paw told me to get accel? was looking i couldnt find it for my car... i have a 225 block double barrel carb with msd wires hell core.. what would be good for me right ? help
PostPosted: Wed Apr 06, 2005 1:30 am
Best one out there is a Standard Ign "Blue Streak". Should be available at local parts stores (NOT Pep Boys). If you have trouble, go to Allied Auto Supply on E. Colorado in Pasadena. They can set you up with that, or a similar quality part if you ask for the good stuff.
I miss those guys...
PostPosted: Wed Apr 06, 2005 6:48 am
I second the Standard-BlueStreak CH-410X recommendation.
Ordinarily I also like NAPA's Echlin ignition parts, but a lot of their MO-4/MO-40/MO-4000 caps seem to be ground off-centre, which can make real problems.
I do like to use the NAPA Echlin long-tip rotor # MO-3000, which is 0.060" longer than ordinary rotors, with high-performance ignition systems.
 Post subject: hmm
PostPosted: Wed Apr 06, 2005 1:58 pm
how about accel?
PostPosted: Wed Apr 06, 2005 2:53 pm
Accel is overpriced. I thought you wanted your parts cheap.
PostPosted: Wed Apr 06, 2005 3:01 pm
Accel is just Echlin's performance brand. The caps in the Accel box are just as off-centre as the ones in the Echlin box.
PostPosted: Wed Apr 06, 2005 3:22 pm
I run a Accel cap,works as good as any.I like the og brown as well.
JZ
 Post subject: steppoooonnn
PostPosted: Thu Apr 07, 2005 12:14 am
the accel are only 29 dollars from summitracing lol
PostPosted: Thu Apr 07, 2005 4:30 am
FOR A DISTRIBUTOR CAP. omgwtflolbbq shift one one one.
PostPosted: Thu Apr 07, 2005 4:59 am
Sham,ya better shop around!!!!!!
PostPosted: Thu Apr 07, 2005 1:34 pm
I've been using mexican made bendix caps. cheap, black, nicely centered, great contacts, perfect fit. If I recall correctly was something neafr 7 bux each. li'l bit slimer wich is great for the tight clearance I have for my big hands around the oil filter.
Juan Ignacio Caino
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 4 guests
