It is currently Fri May 08, 2026 5:15 am
 Post subject: posi-traction?
PostPosted: Mon Apr 11, 2005 8:47 am
did the 71' gold duster 225 come with posi-traction?
Don't ever take a fence down until you know why it was put up.
-Robert Frost (1874-1963)
PostPosted: Mon Apr 11, 2005 9:27 am
The Gold Duster was a trim package only. Sure-Grip (Chrysler's term for limited-slip differential -- "Positraction" is a GM term, yucky!) was available in the '71 A-body as an extra-cost option on all models.
 Post subject: Re: posi-traction?
PostPosted: Mon Apr 11, 2005 11:45 am
Not unless it was made by shivvy... (see Dan's note above)
D/W
If it ain't broke, fix it!
PostPosted: Mon Apr 11, 2005 2:07 pm
Sure-grip in a slant? Probably not unless the owner wanted otherwise.
You've probably got a 7 1/4 rear also with 2.76 gears. (just guessing)
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Apr 11, 2005 5:31 pm
Why not? The sure grip was available in all rears (even the 7 1/4) and all engine sizes.
I even have a 7 1/4 with 5.13 (Direct Connection) gears and sure grip.
PostPosted: Mon Apr 11, 2005 5:49 pm
Sure grips are not just for racing you know...
Sometimes you run into snow, or mud or sand, and I think slant cars get there more often than a hemi car.
If chrysler wanted a drag only rearend, I think it would have a spool?
I have never seen a aspen wagon without a sure grip.
PostPosted: Mon Apr 11, 2005 5:52 pm
Do they still make limited slip units for the 7 1/4? I've been searching high and low for one with no luck.
82 D150-225/727
PostPosted: Mon Apr 11, 2005 6:01 pm
Not that I know of. Just keep watching Mopar forums/mail lists, and e-bay. They do turn up once in a while. I got one through this site, about a years or so, ago.
PostPosted: Mon Apr 11, 2005 6:08 pm
This site implies that limited-slip diffs are still available for the 7-1/4".
PostPosted: Mon Apr 11, 2005 6:34 pm
Interesting they list a 3.21 and not a 3.23.....
"Positraction units we offer include Lockrights by Powertrax, Auburn, Detroit Lockers, Trac Loc and ARB air lockers."
Do you think they have an ARB locker for my Valaint?
I think you worded well when you said "implied" Dan.
PostPosted: Tue Apr 12, 2005 8:35 am
I just called ther 800 number, about the 7 1/4 limited slip rear. They are supposed to call me back, and let me know, if they are available, also whether the repair kit clutch packs are available.
PostPosted: Tue Apr 12, 2005 2:12 pm
Thanks, Sandy. I said "implied" instead of "says", because it looks like boilerplate text they include on every rear axle page, so it's entirely possible that they have nothing in the way of locking diffs for the 9-bolt.
