It is currently Tue Oct 13, 2026 5:09 pm
 Post subject: head rebuild
PostPosted: Sat Apr 16, 2005 10:48 am
Hi all
I'm going to be pulling the head off of my /6 and doing a basic rebuild
Does anyone have any cheep but effective improvemets I can make to it while I have it on the bench
I'm thining of doing some porting. So some advice about this would be helpfull.
Also going to deck it 30 thou. Do you think I should deck more?
It's a stock late sixties dart with the two barral set up.
I just want it make it an 'improved' daily driver without spending big $
many thanks
TMan
'67 Dart 225 Super Six
PostPosted: Sat Apr 16, 2005 4:35 pm
Put some sort of thermal coating on the valve faces to help reduce the chances of detonation.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Apr 18, 2005 5:36 am
Do the porting work and "Back-cut" the intake valves.
Also deburr / remove any sharp edges out of the combustion chamber.
I would take at least .060 off the head.
PostPosted: Tue Apr 19, 2005 5:20 pm
Car Model: 1964 Valiant Sedan
Is there a hard and fast reason why it is almost universally recommended to cut the head to gain compression rather than cutting the block? It would seem that either way would work and that by cutting the block you have a more precise measure on how much you are bumping the compression because the cylinder is perfectly round whereas the head cavity is not.
64 Valiant
PostPosted: Tue Apr 19, 2005 5:59 pm
My first thought, is that by shaving the block you will obliterate the engine serial number. Second, if you want to go back to stock you have to replace the block rather than the head. Im sure there are more.
PostPosted: Tue Apr 19, 2005 6:04 pm
A head is also a lot easier to strip and setup in a mill.
PostPosted: Tue Apr 19, 2005 6:43 pm
Either way is fine. Mainly it depends on which you have apart to do machining on. Too much off either (0.100" is safe) will decrease strength though.
