It is currently Sun Jun 07, 2026 7:35 am
 Post subject: starter problem
PostPosted: Sat Apr 16, 2005 11:09 am
i thought my starter would not turn over because my headers are so close the heat was causing it to seize up. today i tried to start it and it turned over 3 times then nothing. any ideas?
'77 Volare..not much to look at but has it where it counts!
PostPosted: Sat Apr 16, 2005 11:12 am
The headers may have overheated it and melted the bearings or the windings in the motor. Replace it with one of those new mini-starters from a late model minivan and wrap it in some of that metallic heat barrier stuff.
PostPosted: Sat Apr 16, 2005 11:26 am
Almost. A minivan (or other FWD) starter will not fit/work. The mini starter comes from an '89-'03 RWD Dodge pickup (Dakota or full-size), B-van, Durango, M-body passenger car (Diplomat/Gran Fury/NYer Fifth Avenue/Canadian Caravelle) with 3.9 V6, 5.2/318 V8 or 5.9/360 V8. Post-'03 and V10 starters won't work either.
Users browsing this forum: Google [Bot] and 9 guests
