It is currently Thu Jul 02, 2026 8:42 am
 Post subject: engine mods
PostPosted: Sun Apr 24, 2005 3:46 pm
Car Model: 1966 Plymouth Valiant
i am wondering if anyone has tried turning down the counter weights on a
forged crank and if so where there any balancing problems???
also are there any aftermarket balancers availible????can a small or big block balancer be modified to work????
has anyone ever used olds valves it looks like with a lash cap they will be the correct lenght and i can turn the head size down to what i need.
any help would be greatly apreciated
thanks vitamindart
PostPosted: Sun Apr 24, 2005 5:45 pm
Some people have lightend slant cranks. Doug had some pictures posted someware, but I couldn't find them. Fisher has a balencer for the slant. Also a big block balencer can be used with some minor modifications, but the pulleys do not line up. Have no idea on the valves.
PostPosted: Sun Apr 24, 2005 7:50 pm
I overheard Doug explaing about the crank lighteneing out in Vegas. IIRC, when the bob weights are cut, Mallory metal has to be added making the entire process a wash.
As far as valves go, Ferrea is making a drop-in Slant valve now that is relatively low cost. (or so I've been told) :shock:
PostPosted: Mon Apr 25, 2005 4:53 am
Answer this question - Why did the factory put the large counter weights on the crank to begin with?
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Mon Apr 25, 2005 4:36 pm
SL6 Racer
I removed 10 pounds from a stock weight crankshaft. THAN I took it to the machine shop and they rebalanced the shaft. This was after the poor guy spend serveral ??? hours TRYING to rebalance it. When I picked up the crank he asked me if this was a running engine because he had never seen a crank so far out of balance.....so I just played dumb and said I didn't have any history of that crank. Well it has been in my car for 2 years now with no problems. It was worth it BUT it was also lots of work and money. As far as damper I just use a big block and change the front seal.
Dave M
PostPosted: Mon Apr 25, 2005 6:54 pm
Also, the later cast crank motors have much lighter cranks, apparently. The 80s ones supposedly only weigh about 55-60 lbs. I believe this is what Rodney has had in the Lancer for the last 3-5 yrs of drags w/ no issues.
