It is currently Wed Jun 17, 2026 5:22 pm
PostPosted: Sun Apr 24, 2005 10:43 am
I took my holley 1920 carb off, and a piece fell out. I cant figure out what it is. Its copper colored and about half inch long, with a few ridges in it, and a point on one end (I think the point was rubber). I cannot figure this out.
PostPosted: Sun Apr 24, 2005 11:06 am
kewl, trivia... could it be the fuel block off piece (I dont know what the technical name is!). It sits inside the end of the fuel line fitting. The end of the float bracket pushes it shut as the float rises ????
65 Dart GT Convertible
http://www.displacedkiwi.com (click on /other then the dart icon, then whatever you want!)
Fuel inlet needle. The 1920s originally had a "captive" inlet needle fully enclosed in the fuel inlet fitting, but some of the aftermarket carb kits come with the separate style. You get a new needle and seat assembly in a carb kit.
PostPosted: Sun Apr 24, 2005 11:30 am
i thought it went somewhere along that line because when i held it up into the air, some fuel came out, then the piece came out, but i didnt see where from. Only problem is it wont fit into the fuel line........
PostPosted: Sun Apr 24, 2005 11:32 am
if it does fit inside the fuel line fitting, im not sure how it came out then because of the bend in the pipe.
PostPosted: Sun Apr 24, 2005 11:41 am
ok, figured it out, had to take the inlet pipe off, the piece fits in there alright, but not sure if points goes into carb or not, but my instinct says no.
PostPosted: Sun Apr 24, 2005 1:23 pm
The inlet needle drops into the "inside the carburetor" part of the fuel inlet fitting, point facing away from the float.
PostPosted: Wed Apr 27, 2005 10:39 pm
ok, i got it figured out, it works alright, although the first couple of starts spewed gas out the carb, not sure what that means though....
but thanks anyways for the help!
PostPosted: Fri Apr 29, 2005 9:40 am
It probably means its installed wrong.
The float mechanism inside the carb is supposed to actuate this needle and shut off the flow of fuel into the carb when the bowl fills- is the float linkage connected to the needle valve?
PostPosted: Sat Apr 30, 2005 5:09 pm
Connected? damn, I have to take the cover off and connect it?!?!?!
PostPosted: Sat Apr 30, 2005 7:15 pm
or you can just leave it as is and drive with your fire extinguisher near your hand. Some asbestos outfit may be neat too... Welcome to the new century Nikki Lauda :lol:
Juan Ignacio Caino
PostPosted: Sat Apr 30, 2005 8:11 pm
haha
I hav'nt taken the fuel bowl off yet, so I will have to figure it out.
PostPosted: Sat Apr 30, 2005 9:47 pm
if you have the later replacement fuel inlet assy, you ain't need to take the bowl appart. You just unscrew the bronze big nut on the passg side and stuff it with the rubber tipped needle (not what you're thinking, huh?) :lol: with the rubber tip facing outside the carb. (Am I clear?)
if your float level is right that may do it. If your float level is off, you may have black smoke outa your tailpipe if you rev it hard in N or P (unloaded)
Juan Ignacio Caino
PostPosted: Sat Apr 30, 2005 11:24 pm
I had the needle in correctly already.......................
and i dont see why i would need to take the bowl off if i can get the needle in the inlet just fine by unscrewing the bronze piece.
PostPosted: Sat Apr 30, 2005 11:52 pm
anyone know where I can get a replacement needle? would a rebuild kit include one maybe? &#@% piece of &#@% $#!+ just got &#@% lost!!!
Users browsing this forum: Google [Bot] and 11 guests
