It is currently Wed Dec 31, 2025 10:48 pm
PostPosted: Thu May 19, 2005 1:01 pm
Hello one and all!
I inherited my grandmothers '62 plymouth valiant with a 225 slant 6 engine that I am currently working on. In the process of the overhaul, I had found out that I need a new head.
So my question is this - does anyone in the California SF Bay area/San Mateo County area have a head for a 225 engine? I need it ASAP for a good price. I don't have that much money, so I'll take any and all offers that are given to me.
Please e-mail me directly or please post a reply.
Corbywolf@yahoo.com
-Kirsten
PostPosted: Thu May 19, 2005 1:20 pm
Kirsten-
Are you sure the car needs a new cylinder head? That's a very odd thing for a Slant-6 engine to need. Perhaps it just needs a new cylinder head gasket? What leads you to believe the head needs replacing?
 Post subject: New head
PostPosted: Thu May 19, 2005 1:27 pm
I am a mechanic - and in the overhaul, the wrong drill was used and now all the exhaust valves will NOT seat properly AT ALL.
Currently, there is NO head gasket attached. The only replacement head has cracks in two of the combustion chambers. The gasket that I took off was in great condition - no cracks.
Yes - I'm sure that I need a new head. I can't send the head out because I only have one car ( the valiant) and I need it to run by the end of this month - no exceptions.
Kirsten
PostPosted: Thu May 19, 2005 1:31 pm
I have been looking into replacing the head on my 63, and I've done a little research here.
If you have a chance to get a 68 - 74 head, grab it.
75-79 heads are also an upgrade, but don't look "original"
As I understand it, 1960 through 1979 heads are interchangeable.
68 and newer have an improved combustion chamber.
Check this chart linked below.
If you go to Slantsix.org home and click on Articles,
there is also an article about "revised combustion chamber"
http://www.slantsix.org/articles/parts-matrix/jpg.htm
 Post subject: Re: New head
PostPosted: Thu May 19, 2005 4:30 pm
That, then, is a very good reason for needing a new head.
On a budget? Go hit www.car-part.com, searchable used auto parts nationwide. Put in 1970 Dodge Dart cylinder head, restrict the search to your local area, next screen pick the 6-cylinder engine, and hit "Search". Results will show interchangeable heads. A '72-up head in good shape is a nice catch 'cause it'll have factory induction-hardened exhaust valve seats.
Or, you could always just send a private message to Doctor Dodge here on the board. He's right in your area and I bet he has a good used head for you.
As far as cylinder head physical interchangeability: 1960 through 1980, all 170, 198 and 225 slant-6s in all applications. The '68-up heads have a slightly better combustion chamber shape, the 1975-up heads use taper-seat spark plugs rather than gasket-seat, and some 1972-up heads have air injection ports you don't need or want, but other than that, they all interchange.
Be sure to check if your '62 has the aluminum block 225 engine which was available from late '61 to early '63! If it does, you must use the special (and hard to find) head gasket; the standard gasket cannot be made to work.
PostPosted: Thu May 19, 2005 5:58 pm
Car Model: 1962 Lancer 770
Kirsten,
If you can wait 3 weeks, I have a 62 head for ya. low miles and in good shape. pm me.
Thanks
Menko
PostPosted: Thu May 19, 2005 10:44 pm
Fresh off car-part.com
Results sorted by PRICE (Click on heading to re-sort)
Click back to modify your previous choice.
Most prices do not include extended warranties or shipping.
Please include YOUR ZIP CODE when requesting a quote.
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
1972
Head(Cylinder)
Dodge Truck 200 Series 225 SLANT 6 CYL,NO SMOG 0P0306 $175 Sierra Auto Recycling, Inc. USA-CA(Ridgecrest) Request_Quote 1-800-346-8733 Request_Insurance_Quote
1965
Head(Cylinder)
Dodge Truck 100 Series GOOD 3077 $150 Navarra Truck and Van Dismantlers USA-CA(San-Jose) E-mail 1-800-628-2772
1965
Head(Cylinder)
Dodge Truck 100 Series 225,2206035-4,MAGED STOCKU $125 Pickup Salvage Co. USA-CA(Bakersfield) E-mail 1-800-323-1401
1974
Head(Cylinder)
Dodge Truck 100 Series CORE 5578 $125 Normans Truck and Auto Parts USA-CA(Escondido) E-mail 1-760-746-2655
1975
Head(Cylinder)
Plymouth Horizon Duster 75 DUSTER 225 ENG CASTING 3698447 HRAC $100 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1978
Head(Cylinder)
Dodge Van not Caravan 100 Series 78 DODGE VAN 6CYL CHECK AIR 4G0171 $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1976
Head(Cylinder)
Dodge Aspen 75-80 225CI.NO-SMOG,CAST.4104362 HRAC $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1976
Head(Cylinder)
Dodge Aspen 75-80 225CI.NO-SMOG,CASTING 3698447 HRAC $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1975
Head(Cylinder)
Plymouth Valiant 75-78 225CI.CASTING 3698447-1 HRAC $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1976
Head(Cylinder)
Plymouth Volare 76 VOLARE 3.7 CAST 3698447-2 4H0059 $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1974
Head(Cylinder)
Plymouth Horizon Duster 67-74 225CI.CASTING 2843169 HRAC $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1975
Head(Cylinder)
Plymouth Valiant 75-78 225CI.NO SMOG CAST.3698447-1 HRAC $75 Dorris Auto Wreckers, Inc. USA-CA(Hayward) E-mail 1-510-782-4392
1976
Head(Cylinder)
1976
Head(Cylinder)
1976
Head(Cylinder)
1978
Head(Cylinder)
Dodge Van not Caravan 100 Series D91150 $75 Delano Dismantling USA-CA(Delano) E-mail 1-877-202-5591
1971
Head(Cylinder)
Dodge Van not Caravan 100 Series CAST 2206035 NN0226 $75 Pacific Auto Salvage, Inc. - ARA Gold Seal, CAR certified USA-CA(American-Canyon) E-mail 1-707-255-1437
1974
Head(Cylinder)
Plymouth Horizon Duster 225 811101 $50.55 Ajax Auto Parts - RPN USA-CA(Coachella) E-mail 1-800-606-6043
1969
Head(Cylinder)
Dodge Dart and 6-225--G 77272 $Call E & J Auto Wreckers, Inc. USA-CA(Hayward) Request_Quote 1-800-440-5865 Request_Insurance_Quote
1976
Head(Cylinder)
Dodge Aspen w/o AIR- 030402 $Call Pearsonville Auto Wrecking USA-CA(Pearsonville) E-mail 1-760-377-4585
Year
Part
Grade Stock# US
Price Dealer Info
OR
Request a Quote from hundreds of recyclers
Mechanical Part Grading A = Less than or equal to 60k miles, or greater than 60k miles but less than or equal to 200k miles and less than or equal to 15k miles per year B = Greater than 60k miles and less than or equal to 200k miles but greater than or equal to 15k miles per year C = Greater than 200k miles
Part Grading Abbreviations Downgrade = Recycler choose to downgrade the part based on damage not reflected in the grading algorithm
Prices are in local currency. USA is the default. Car-Part.com is not responsible for any errors or omissions. Information is responsibility of individual Auto Recycler. © 1998-2005 Car-Part.com
'62 Plymouth Savoy Wagon
'64 Chrysler 300
'47 Farmall H
Merlins are cool
Radials rule
Jets drool
PostPosted: Fri May 20, 2005 5:43 am
I will beat any price on a good used SL6 Cylinder head! :wink:
Seriously, I have a few of these and am close, in Sunnyvale.
PostPosted: Fri May 20, 2005 10:01 am
Thanks!
My eingine is my class project for this semester, and my professor allowed a few guys in my class finish off the drilling - which screwed it up.
At the beginning, the guy who was teaching me how to drill out the old valve guides gave me the Chevy drill and NOT the Chrysler drill..
PostPosted: Fri May 20, 2005 10:46 am
Nobody beats a Dealin' Doug deal...Nobody!
PostPosted: Mon May 23, 2005 2:27 pm
What are you willing to offer? I'm in the market for some spare parts. I am looking at the sites suggested above, and I am curious as to what kind of a deal your willig to make.
PostPosted: Mon May 23, 2005 2:44 pm
Doug, give her a head that need chevy valves ImageImageImageImage
PostPosted: Tue May 24, 2005 12:34 pm
LOL!! As long as it will work. If I haven't said so already, I'm tryin to keep everything as original stock as possible - just so you have an idea as to what I'm lookin for.
PostPosted: Tue May 24, 2005 10:05 pm
Bone stock and well used SL6 head, $40.00
Come and get it!
PostPosted: Tue Jun 14, 2005 11:49 am
Come and get it!
:?: How well used is it?? :?:
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 15 guests
