It is currently Thu May 07, 2026 2:19 am
 Post subject: New Brakes
PostPosted: Tue May 31, 2005 3:20 pm
so new 9" drums, shoes, hardware, rebuilt Master C. , and rubber hoses
how is the pedal suppose to feel after a rebuild? mines returns slowly, like if the cylinders are pushing the pedal back out, is this right? or am i in deep doo doo..???
the car stops really good, feels nice and tight, just that the pedal returns slowly, is this a cause for worry?
70 Plymouth Valiant 4dr
PostPosted: Tue May 31, 2005 3:33 pm
There should be a coil return spring around the brake pushrod.
My original had disintegrated, and I made a new one with piano wire
PostPosted: Tue May 31, 2005 4:59 pm
The return spring doesn't do anything other then protect the rubber boot.
I would check the adjustment of the individual brakes and then bleed the lines. A slow return of the brake pedal could also mean a bad master cylinder. A common problem with the 9" brakes.
PostPosted: Tue May 31, 2005 5:00 pm
Could also have problematic residual-pressure valve(s) in the master cylinder. What year car is this?
PostPosted: Tue May 31, 2005 6:59 pm
70 valiant
master cylinder was rebuilt, new springs and such and the seats were changed also, the cylinder inside looked good, no gashes or anything
the brakes also started making a squeal, on the front driver side, is it because they are new???? :roll:
PostPosted: Fri Jun 03, 2005 7:14 am
Make sure that all of the pads are adjusted so there is no too much travel before the shoes contact the drums.
