It is currently Sat Dec 27, 2025 9:27 pm
PostPosted: Thu Jun 02, 2005 7:57 pm
i'm looking to find out weather i can change these cranks and wich will serve my purpose best as most of you know i have a 85 ram with a older solid liftered 225 and i beleive the engine i got the other crank out of is out of a hydrolic liftered engine but when i set the two cranks up beside each other i found one is built much heavier then the other so i did some looking and found they had diffrent cranks for trucks i'm wondering how long they did this as well but i did get the numbers off both which read
4095246 8 this is the lighter of the two out of the solid liftered engine
3698966-1 and this is the one out of the hydrolic liftered engine
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Thu Jun 02, 2005 8:44 pm
The crank difference isn't solid/hydraulic lifter, it's forged/cast crank. All Slant-6s up to midyear '76 production have the forged crank. From midyear '76 on, the cast crank was used. Forged and cast cranks do not interchange (bearing size/location differences, etc.)
PostPosted: Thu Jun 02, 2005 10:40 pm
wasn't sure if there were more oil ducts in the crank for the hydrolic engines or not but they are both cast so now it just a matter of which will work best for my ram as it will do some hauling of my 75 coronet
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Thu Jun 09, 2005 10:57 pm
i have read some were that they used diffrent cranks for trucks and they used both cranks from 77 to 82 now it's just a matter of which is for what
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Fri Jun 10, 2005 9:16 am
The 225-2 and 225-3 heavy-duty slant-6 engines (1961 through 1976) got shotpeened cranks.
Which "both"?
PostPosted: Mon Jun 20, 2005 9:58 pm
3698966-1
them are the part numbers i got off both cranks and i looked them both up on a parts matrix that i was sent a link to when i first found this site
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Jun 20, 2005 10:12 pm
Cast cranks and forged cranks do not interchange.
Measure the width of the bearing journals, the cast crank has narrow journals, to make up for the weaker cast iron material they are made of.
PostPosted: Thu Jun 23, 2005 8:35 pm
the journals are the same i'm simply trying to find out how i ended up with two diffrent crankshafts and thanks for the info knowing they did run a diffrent crank in the truck engines from 61 through 76 but did they continue after they changed to from forged to cast
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Thu Jun 23, 2005 9:02 pm
No, all are the same so just use the crank that is in the best condition.
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
