It is currently Sun Nov 22, 2026 12:42 pm
 Post subject: 63 D-100
PostPosted: Wed Sep 21, 2005 4:26 pm
I recently took on the job of totally restoring a 1963 D-100 truck for a friend and am totally confused about getting the motor out. I have swapped many motors before, but I am having problems with this one. Do I have to pull the trans (standard) with the motor or do they come apart? I have removed all bolts and they will not separate and I cannot get them out together. Also, what is the correct color for thew engine? Any ideas will help. Thanks mike
PostPosted: Wed Sep 21, 2005 5:38 pm
Yes, the engine and trans will separate, though you can also remove them together if you prefer. Could be the clutch plate is stuck to the flywheel surface, if the truck has been sitting a long time.
Slant-6 engine color in a '63 D100 is usually yellow (approximately John Deere yellow), some early-production '63s got red.
 Post subject: D-100
PostPosted: Thu Sep 22, 2005 6:33 am
Thanks, I did get it out together, there are holes in the crossmember, I just could not find the bolts due to the large amount of grease and dirt from 42 years of use. It took a lot of blood, sweat and bad language to get it out. Thanks again. mike
i
 Post subject: Welcome Sweptliner!
PostPosted: Thu Sep 22, 2005 8:55 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Mike--
Be sure to visit the fine folks at www.sweptline.org They'll be happy to share any D100 tips you need. And they're a great bunch of guys besides.
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
 Post subject: language
PostPosted: Thu Sep 22, 2005 6:37 pm
Car Model: '63 Dart GT Convertible
Yes, it always helps to be a cunning linguist.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
Users browsing this forum: Amazon [Bot] and 15 guests
