It is currently Fri Jun 05, 2026 7:10 pm
 Post subject: speedo rebuild
PostPosted: Tue Sep 27, 2005 5:58 am
Anyone have their speedo rebuilt. The odo on my valiant keeps sticking which causes the speedo to go nuts. I'm tired of taking the cluster out to unstick the thing so I just want to send one off and reinstall a working one. Thanks in advance
PostPosted: Tue Sep 27, 2005 6:41 am
Slantsix Dan has a company he used with excellent results-- also there is a company on ebay advetrtising such services
http://cgi.ebay.com/ebaymotors/1966-PLY ... enameZWDVW,,
good luck
PostPosted: Tue Sep 27, 2005 10:11 am
Here y'go; these guys do excellent work.
PostPosted: Tue Sep 27, 2005 10:20 am
Dan I would like to say thanks again for more of your extensive knowledge
PostPosted: Fri Sep 30, 2005 12:55 am
other than my speedometer needing to be rebuilt, my panel lights now go on and off so at night sometimes i can and sometimes i can't see my temp, alt or fuel guage.
plus there is a huge rip in my dash.
would it be possible to take a whole dash/panel assembly from another car at a scrap yard and just interchange the whole thing and hope for a good speedometer from them?
can i just interchange guages if one of theirs doesn't work?
can i advance their odometer to match mine?
God took you away, then brought you back to me.
 Post subject: Calibration........
PostPosted: Fri Sep 30, 2005 2:45 am
Do they calibrate the speedometer when they rebuild them?????
PostPosted: Fri Sep 30, 2005 8:36 am
Yep
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Sep 30, 2005 1:14 pm
Let me clarify a little.............
An actual calibration, where they get the odometer and speedometer to agree. (I'm not talking a gear ratio change). It's very common to have different errors between the two systems, and you can with gear ratio changes you can get either the odometer or speedometer to read correctly, but not both at same time............ (i.e. my odometer is within 1%, but at higher speeds my speedometer is 5%+ off.......)
 Post subject: speedo in cali
PostPosted: Fri Sep 30, 2005 1:40 pm
any of you fellas know of a shop that rebuilds speedos in southern california? I am willing to ship my cluster to get it done right, but would rather drive my car in to a reputable shop.
i am in los angeles area.
thanks
caesar
PostPosted: Mon Oct 03, 2005 12:50 pm
Dash panel lights going on and off intermittantly could be due to a bad headlight switch. I had that problem in a 64 Valiant, and a new headlight switch from NAPA has solved the problem.
PostPosted: Sun Oct 30, 2005 10:59 am
hey mixolydian,
I got my headlight switch electrical unit, i was able to find the button that releases the actual switch you pull to turn on the lights, but i can't figure out how to release the old electrical unit and remove it. I have made notes so that i know which color wire goes on which terminal. all i need is to be able to release that old electrical unit. any tips?
and BTW, laying upside down with your head against the brake pedal and your arms paralyzed by the lack of space is not a comfortable position to be in for any period of time. yuck.
