It is currently Wed Nov 18, 2026 12:27 am
PostPosted: Sat Oct 01, 2005 10:49 pm
I have a 73 motor with a cracked exhaust manifold, i want to put headers on instead of a stock replacement manifold, do i also need to change out the intake if i use headers?
-alex
mopar or no car!!!
PostPosted: Sat Oct 01, 2005 11:02 pm
from what i gather it would depend on what kind of headers ur lookin at...research is good
My Dart
GO VOLS!
It's not rocket science, we're just splitting atoms.
PostPosted: Sun Oct 02, 2005 5:10 pm
no, you can use the stock intake.
 Post subject: headers
PostPosted: Sun Oct 02, 2005 9:21 pm
yes you can use the stock intake. however, if you use the clifford headers, the flanges are different thicknesses. you need to use a thick and soft manifold gasket to get it to seal up. i have a leak on #4 that won't seal up because the difference in thickness.
zedpapa
soon to have 5 gears!!!
PostPosted: Mon Oct 03, 2005 5:38 pm
4 sets of Clifford headers, I have, are all 1/2 inch flange. The MP headers I have seen, have a thinner flange with, (I think) a nut welded on, where the triangle washers go.
PostPosted: Mon Oct 03, 2005 11:29 pm
My Clifford headers have the thick flange also. I am using an Offy intake. I don't know if it is different than stock.
PostPosted: Tue Oct 04, 2005 4:10 am
The Offie, Clifford and factory manifolds, I have in stock, all have the same flange thichness, within manucturing tolorances.
PostPosted: Tue Oct 04, 2005 2:22 pm
my clifford headers hava a thinner flange than my clifford 4 barrel intake.
I ground around an 1/8" off of one side of the triangle washers to make everything seal up nicely.
PostPosted: Mon Oct 10, 2005 6:18 am
On my mopar headers I welded 3/16" spacers on the flanges where the triangle washers make contact.This brought it up to the same thickness as my offy intake.It seals no problem with a Mr Gasket 320 gasket.
72 Scamp dual 1 brl
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 7 guests
