It is currently Tue Jun 16, 2026 2:10 pm
PostPosted: Sat Oct 08, 2005 6:21 pm
My 66 Dart Wag has a curious fuel gauge prob. When the tank is full, it reads full. When the tank is down 1/4 it reads empty. The temp gauge is unaffected (reads properly and predictably.) Is this a faulty gauge?ground? limiter? sending unit? or . . . ? Any help is much appreciated :D
PostPosted: Sat Oct 08, 2005 6:26 pm
Im guessing sending unit or punctured float thats sinking.
 Post subject: broken wire
PostPosted: Sat Oct 08, 2005 6:50 pm
Sounds like a broken resistance wire in the sender unit. While the wiper
is above the break the gauge works fine. When the wiper is below the
break the broken wire effectively causes an open circuit to the gauge.
A sunk float usually makes the gauge read low all the time - So I do not
think it is a sunk float.
 Post subject: All fixed
PostPosted: Sun Oct 09, 2005 5:43 pm
I swapped the sending unit and the gauge woke right up. Thanks!
. . . there was good sport at his making.
PostPosted: Sat Oct 22, 2005 9:19 am
:shock: another 1966 dart sw thats awesome and its got a slant i take it :P awesome
Cuda Progress :D
The dart as it sits now :(
