It is currently Sun May 17, 2026 8:32 pm
PostPosted: Thu Oct 13, 2005 12:47 pm
How much of a tempature increase are some of you all noticing when
having the head shaved .100 or more???
PostPosted: Thu Oct 13, 2005 3:12 pm
With a good rad you should not notice any difference. I was having cooling problems last summer but I replaced my rad with a new extra capacity V8 W/ air rad and I never even came close to over heating in near triple digit temps this summer. Never got over 2/3's on the gage even after running it hard.
PostPosted: Fri Oct 14, 2005 7:13 pm
Thanks '70 valiant. Are you using the stock fan as well???
PostPosted: Sat Oct 15, 2005 12:07 pm
nope I am using a 16" pusher from a mercedes I found in a yard.
PostPosted: Sun Oct 16, 2005 7:09 pm
on the same topic...anyone know of a place i can get a radiator shroud for my 71 swinger 225? the local u-wrench-it maybe (ooops its pick-n-pull now :shock: )?
My Dart
GO VOLS!
It's not rocket science, we're just splitting atoms.
 Post subject: ? for '70 valiant...
PostPosted: Sun Feb 19, 2006 3:07 pm
What length pushrods are using on your engine ??? Was wanting to take .125 of my head and was wondering some suggestions for pushrod
length....help??!!
PostPosted: Sun Feb 19, 2006 4:11 pm
I am using stock length push rods at 0.100". I would suggest you not remove more than that from the head. my chambers are only 39cc's. If you are looking for compression I would suggeest decking the block as well as shaving the head.
