It is currently Wed May 06, 2026 4:25 am
PostPosted: Wed Oct 19, 2005 7:56 pm
SBP 11" rotor/hub, KH calipers. How does the rotor seperate from the hub, are these things pressed on? There is a machine shop I could go to but I wondered if anyone has a home remedy.
"that's a nice car....are you gonna fix it up some day?"
PostPosted: Wed Oct 19, 2005 11:54 pm
Held together by the studs - bang out the studs and they fall apart.
Take one hammer with 2 flat ends (love my terminology?) and place it over the stud. Then take another hammer and bangbang. Heavier one hand sledges work well. If you want to reuse the studs, put a lug nut on them upside down until its flat with the stud top.
PostPosted: Thu Oct 20, 2005 4:15 am
It's not a good idea to strike the face of a hammer with another hammer. Hammer faces are often hardened and may chip when struck together. The resulting chip will be a small, very sharp, missile which can easily penetrate flesh. I've seen it happen and it isn't pretty. Used a drift or unhardened steel rod and keep the mushroom impact ridge ground off smooth or it will do the same thing. Or better yet, take it to a garage or machine shop and have it pressed out.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Oct 20, 2005 11:55 am
I used a brass hammer in the middle so it was a bit softer... hmm, never heard of this flesh penetrating missile phenomenon
Taking it to a shop to have the studs pressed out just seems wasteful, find something to put in the middle, a hard piece of wood maybe or some other metal stock. I just said another hammer because it has a handle so you don't have to have your fingers anywhere near a striking hammer.
PostPosted: Thu Oct 20, 2005 5:56 pm
wood will be too soft. An untempered steel bar would work or a large punch; you could hold them with vice grips to keep your hand away. Be sure to wear eye protection and heavy leather gloves would be prudent as well. A press is still the right and safest way to do it.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Oct 21, 2005 1:07 pm
I got them seperated and the studs out by using the lug nut suggestion. I put them back on, flat side up, level with the top of the stud. A couple good shots with a small sledge got them out. Actually came out eaiser than I thought, and no damage. Thanks for the help.
